Stuck on 3.4.23088 / RWData full
2014 Fusion Hybrid S retrofitted to Sync 3 from Sync 1 with 8" “regular” control panel and APIM from a 2017 escape.
So I’ve been trying for like two days to get past this. I created a rwdata cleaner flash drive as well as a full install drive. If I put the rwdata cleaner in most times I get a err12, every once in a while I get “update will be installed on next reboot” but even if I can get it to reboot it still gives an err12 trying to do a full install. I’ve tried soft resetting with forscan (the power + FF method doesn’t work, not sure why) waiting, and a number of other things and I’m running out of ideas. I have a backup non-nav APIM but would like to get this one fixed. If I get the rwdata cleaner to work it stops hanging completely and staying stuck on backup camera etc but it won’t ever actually let me do an update.
Old SYNC Version: 3.4.23088
INST_ERR12
Version: 0.0.00000
Model: Corsair Voyager 3.0 USB Device
Size:
; CyanLabs Syn3Updater 2.12.2.0 Stable - Autoinstall Mode - RWData Cleaner
FILES (1)
[10/20/2023 10:31:29 PM] Selected Region:  - Release: RWData Cleaner - Map Version:
[10/20/2023 10:31:29 PM] Install Mode: Auto-Detect (autoinstall) Forced: False
[10/20/2023 10:31:29 PM] MY20 Protection: Auto-Detect
[10/20/2023 10:31:29 PM] Formatting USB drive
[10/20/2023 10:31:29 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[10/20/2023 10:31:36 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/20/2023 10:31:36 PM] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/20/2023 10:31:37 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/20/2023 10:31:37 PM] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/20/2023 10:31:37 PM] Preparing USB drive
[10/20/2023 10:31:37 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/20/2023 10:31:37 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/20/2023 10:31:37 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[10/20/2023 10:31:37 PM] Generating Autoinstall.lst
[10/20/2023 10:31:37 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
2013-2015 Fusions came with SYNC 2/MFT. The 2010-2012 Fusions came with Sync 1.
Then what are we calling 4" non touch screen sync exactly these days. Since ford never gave any of them a number until sync 3 anyway. A little surprised at the unhelpful semantics post from someone who generally has a lot of knowledge on these topics.
It’s a forum, community driven, bill is a user just like you, he also isn’t wrong.
If rwdata cleaner ain’t working especially with your other symptoms I’d say your apim is failing
