Hello, I’m trying to update my Sync3 from version 3.4 build 21265 to 3.4 build 22251 and the update is stuck on Updating System Software. I have changed the USB drive, master reset, but not luck. Here are my log files when I create the usb drive.
Version: 3.4.21265
; CyanLabs Syn3Updater 2.11.8.0 Stable - Autoinstall Mode - Sync 3.4.22251 NA
Item1 = VOICE - 5U5T-14G391-CS_1660783942000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G391-CS_1660783942000.TAR.GZ
Item3 = APPS - NU5T-14G381-AB_1665525837000.TAR.GZ
Open3 = SyncMyRide\NU5T-14G381-AB_1665525837000.TAR.GZ
FILES (3)
[4/4/2023 9:38:39 AM] Selected Region: NA - Release: Sync 3.4.22251 - Map Version: Non Nav APIM
[4/4/2023 9:38:39 AM] Install Mode: Auto-Detect (autoinstall) Forced: False
[4/4/2023 9:38:39 AM] MY20 Protection: Auto-Detect
[4/4/2023 9:38:39 AM] Formatting USB drive
[4/4/2023 9:38:39 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[4/4/2023 9:38:47 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[4/4/2023 9:38:49 AM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[4/4/2023 9:38:49 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[4/4/2023 9:38:51 AM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[4/4/2023 9:38:51 AM] Checking Existing File: NU5T-14G381-AB_1665525837000.TAR.GZ
[4/4/2023 9:38:53 AM] Validated: NU5T-14G381-AB_1665525837000.TAR.GZ (Skipping Download)
[4/4/2023 9:38:53 AM] Preparing USB drive
[4/4/2023 9:38:53 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[4/4/2023 9:38:53 AM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[4/4/2023 9:39:29 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[4/4/2023 9:39:30 AM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[4/4/2023 9:39:30 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[4/4/2023 9:39:30 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[4/4/2023 9:40:26 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[4/4/2023 9:40:28 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[4/4/2023 9:40:28 AM] Checking Existing File: NU5T-14G381-AB_1665525837000.TAR.GZ
[4/4/2023 9:40:28 AM] Copying: NU5T-14G381-AB_1665525837000.TAR.GZ
[4/4/2023 9:41:55 AM] Validating: NU5T-14G381-AB_1665525837000.TAR.GZ
[4/4/2023 9:41:58 AM] Copied: NU5T-14G381-AB_1665525837000.TAR.GZ
[4/4/2023 9:41:58 AM] Generating Autoinstall.lst
[4/4/2023 9:41:58 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Can you let me know what I’m doing wrong.
Also here is the APIM Interrogator Logfile info
<?xml version="1.0" encoding="UTF-8"?><p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2023-04-04” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN></p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNCGEN3</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue=“c238000b”/>
<d2p1:DTC DTCValue=“919f130b”/>
</p:BroadcastDTCType>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:Response5U5T-14G381-EU</d2p1:Response>
</d2p1:DID>
d2p1:Response355535542d3134473339312d435000000000000000000000345535542d3134473432332d434300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:ResponseBlank</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:ResponseVVA2F4AA</d2p1:Response>
</d2p1:DID>
d2p1:Response00</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:Response
</d2p1:Response>
</d2p1:DID>
d2p1:Responsea8:1b:6a:0e:3f:0c</d2p1:Response>
</d2p1:DID>
d2p1:Responsea8:1b:6a:0e:3f:0d</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2023-04-04T10:08:46+00:00” RAM=“1494310912” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“465M” available=“3.2M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/grace” total=“775M” available=“5.8M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“917M”/>
<d2p1:PartitionHealth type=“/fs/mp/” total=“1.4G” available=“132M”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“3.0G” available=“1.7G”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Thanks
