pongolo
(pongolo)
October 2, 2023, 6:00pm
1
Hello,
I have a 2016 Ford Expedition w/Nav and yesterday updated SYNC3 to 3.0.20204 from 1.0.15139 using the Ford website (via USB). I’m having issues where I don’t have Android Auto as an option and I’ve tried different cables with no success. I used the Syn3 Interrogator to get some data from the unit and when I try to read the XML file, Syn3 crashes. The XML file does have information and looks to be properly formatted so not sure why it’s crashing. I’ve tried the Reset Settings button but Syn3 keeps crashing.
The error is long but it starts with the following:
"Syn3 Updater has crashed.
An error occurred and couldn’t be handled.
If you keep experiencing this issue try using the “Reset Settings” button below
Cannot deserialize the current JSON object…".
Thanks for the help!
Old SYNC Version: 1.0.15139
New SYNC Version: 3.0.20204
Syn3 crashes when trying to read the XML file generated by the Interrogator
pongolo
(pongolo)
October 2, 2023, 6:09pm
3
Here’s the XML file…
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2004-02-16" xsi:schemaLocation="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0 ModuleSnapshot.xsd">
<p:VIN>XXX</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue="f0000408"/>
<d2p1:DTC DTCValue="e0175108"/>
</p:BroadcastDTCType>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>JR3T-14G381-AX</d2p1:Response>
</d2p1:DID>
<d2p1:Response>4a5233542d3134473339312d434500000000000000000000474235542d3134473432322d434a000000000000000000004a5233542d3134473432332d434200000000000000000000474235542d3134473432312d434a00000000000000000000474235542d3134473432342d434800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>a124108f</d2p1:Response>
</d2p1:DID>
<d2p1:Response>e9593705</d2p1:Response>
</d2p1:DID>
<d2p1:Response>b222050128028300000a</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>0100000300</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01000800000002</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1a2c1a402e7c</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>2200330000000008eb000056569a0077</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-GB5T-14G371-AF</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G380-BC</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G371-CFC</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>WV1M02L2</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>GB5T-14G374-AF</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>68:c9:0b:ec:c7:24</d2p1:Response>
</d2p1:DID>
<d2p1:Response>68:c9:0b:ec:c7:25</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2004-02-16T11:31:42+00:00" RAM="1234567" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/usb0/" total="30G" available="30G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
CyanLabs
(CyanLabs)
October 2, 2023, 6:31pm
4
Can you post the unedited file, i need the encoding and stuff which isn’t visible when copy and pasting, DM if you want, i won’t reply to DM’s though
pongolo
(pongolo)
October 2, 2023, 11:23pm
6
Hello, just checking to see if you received the file and were able to open it.
CyanLabs
(CyanLabs)
October 3, 2023, 7:51am
7
Received, i will look at it when i can, please be aware of timezones
CyanLabs
(CyanLabs)
November 29, 2023, 4:40pm
9
I completely forget about this, did you manage to solve it without me?
pongolo
(pongolo)
November 30, 2023, 10:43am
11
Hello,
Yes, i was able to eventually get it working.
Thanks
CyanLabs
(CyanLabs)
December 1, 2023, 9:52am
12
Thanks for the update, i still need to review the file to see where the issue is, but i haven’t had time recently.
