Syn3 Updater 2.12.2.0 Interrogator issue
My APIM was replaced due to cold weather issue. The Build Date is 9/2023 SO I believe its a MY2020+ however the interrogator shows
Version NU5T-14G381-AB
APIM Model: Unknown
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 4.2G
12/4/2023 1:14:09 PM +00:00
which then won’t pick proper updating methods I and on the dreaded 3.4.22251_PRODUCT and am having some of the know issues.
Additionally I would like to update to 2.22 NA maps with updated voice (which I think will require Fmods nav deleted and installer since I believe the APIM is 2020+)
Is there anything I can do to help Syn Updater help me help myself?
D.
Install Type: OEM Replacement
Old SYNC Version: 3.4.22251
New SYNC Version: 3.4.22251
VIN: 1FTEW1Exxxxxxxxx 2017 F150 date on replacement APIM 9/2023
APIM Model: Unknown
APIM Size: 32GB
Partition Type = Free / Total
/fs/sd/MAP/ = 12M / 1.5G
/fs/sd/MAP/ = 12M / 1.4G
/fs/sd/MAP/ = 10M / 1.4G
/fs/sd/MAP/ = 2.9M / 951M
/fs/sd/MAP/ = 8.6M / 1.3G
/fs/sd/MAP/ = 14M / 1.8G
/fs/sd/MAP/ = 17M / 1.7G
/fs/sd/MAP/ = 6.7M / 1.4G
/fs/Nuance/ = 15M / 1.6G
/fs/Nuance/ = 10M / 1.1G
/fs/Nuance/ = 24M / 2.5G
/fs/Nuance/ = 3.2M / 465M
/fs/rwdata/ = 919M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 17K / 496K
/fs/mp/ = 82M / 1.4G
/fs/images/ = 4.2G / 25G
Installed Packages
4U5T-14G421-CAE
4U5T-14G421-CBE
4U5T-14G421-CCE
4U5T-14G421-CDE
4U5T-14G421-CEE
4U5T-14G421-CFE
4U5T-14G421-CGE
4U5T-14G421-CHE
4U5T-14G421-CJE
5U5T-14G391-CS
4U5T-14G422-CAK
4U5T-14G422-CBK
4U5T-14G422-CCK
4U5T-14G423-CC
APIM AsBuilt
DE00: 2280001340020008008A
DE01: 555300000000000028000000
DE02: 0000000000
DE03: 01000000000000
DE04: 000000000000
DE05: 00
DE06: 0A000000000000000000000000000000
From LCD in Truck
VMCU Version :5.4.28.0
CCPU Version 3.4.22251_PRODUCT
Navigation Application Version :3.100.566340
Map Database Version :NA 2 21
Voic Control Application Version :77.40_RC4
POI Database Version :NA 2 21
Assembly Part Number :MU5T-14g371-CBG
H/W Part Number:1U5T-14g380-EF
CCPU S/W Part Number :NU5T-14G381-AB
VMCU S/W Part Number :1U5T-14G374-EM
Calibration S/W Part NUmber :1U5t-14g375-DA
Pushing the correct buttons on SynUpdater will give you what you need.
Could you be a liitle more specific? As I understand I can easily brick my brand new apim with the wrong settings
You are correct that your APIM is a 2020+ and you should choose accordingly as such so do not reformat. You cannot update to NA 2.22 maps with a 2020+ APIM and Cyanlabs.
You can however still do the SYNC updates just fine.
Agreed, if you know your unit is MY20 there’s no point in running the interrogator log: keep MY20 protection active at all times.
However, everything in Syn3 REALLY wants that populated I am almost tempted to go looking for a proper part num to put in the unknown to shut it up. It’s very nerve-racking to have it scream at you every step of the way
The part number will be the assembly number in this case, MU5T-14g371-CBG. As Bill says above, this is a MY20+.
I’m not sure what you are talking about.
If you configure Syn3Updater accordingly there would be no reason for it to have a proper interrogator log read…
