thanks bill
Do you have an IPMB? Do you have either the 360 cameras or Backup assist? If not this should not be turned on as you would not have that module.
I don’t think it is the LIN circuit as that goes to the BCM not the APIM. Honestly, I think it is the wire harness. If it were me, I would trace the pins and check for continuality just to rule it out.
No backup assist or 360 cams
When I did my upgrade I had exactly the same issue. Turned out the RCA adapter on the conversion harness had loose connections.
I ended up getting an adapter and bridged it between the harness and the APIM and used the RCA plug on it instead. Worked immediately
