Sync 2 to Sync 3 Upgrade Issues with Climate Control/Voice Assistance
Hi everyone!
I just did a sync 2 to sync 3 upgrade in my 2015 Ford Explorer XLT with a unit that came out of a 2017 Ford Explorer. The old sync 2 module is equipped with navigation and so is the sync 3 module. Everything went well except a couple minor issues. For whatever reason none of the climate controls on screen are working, neither is my voice assistant (clicking button on the wheel), or the radio presets. When I click a radio preset, it just doesn’t tune to that channel. Though direct tuning, and tuning from the button panel along with the head cluster works. I’d like to note that I don’t have a upgraded USB hub installed yet that is compatible with sync 3, as I consistently get the incompatible USB message after starting the car. Is this what is causing the issues?
I’ve attached my AsBuilt data below from both the Sync 2 and Sync 3 modules. Thanks!
Install Type: OEM Replacement
Old SYNC Version: 2.0.16074
New SYNC Version: 3.4.22251
Version: 2.0.16074
FileSystem: NTFS
; CyanLabs Syn3Updater 2.11.8.0 Stable - reformat  Mode - Sync 3.4.22251 NA
FILES (17)
[12/4/2022 12:54:47 AM] Selected Region: NA - Release: Sync 3.4.22251 - Map Version: 2.21 (2021) - NA
[12/4/2022 12:54:47 AM] Install Mode: Auto-Detect (reformat) Forced: False
[12/4/2022 12:54:47 AM] MY20 Protection: Auto-Detect
[12/4/2022 12:54:47 AM] Formatting USB drive
[12/4/2022 12:54:47 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[12/4/2022 12:54:55 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[12/4/2022 12:54:55 AM] Downloading: 1u5t-14g386-cb.tar.gz
[12/4/2022 12:54:59 AM] Validating: 1u5t-14g386-cb.tar.gz
[12/4/2022 12:54:59 AM] Downloaded: 1u5t-14g386-cb.tar.gz
[12/4/2022 12:54:59 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/4/2022 12:54:59 AM] Downloading: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/4/2022 12:56:22 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/4/2022 12:56:23 AM] Downloaded: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/4/2022 12:56:23 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/4/2022 12:56:23 AM] Downloading: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/4/2022 1:00:03 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/4/2022 1:00:04 AM] Downloaded: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/4/2022 1:00:04 AM] Checking Existing File: NU5T-14G381-AB_1665525837000.TAR.GZ
[12/4/2022 1:00:04 AM] Downloading: NU5T-14G381-AB_1665525837000.TAR.GZ
[12/4/2022 1:03:58 AM] Validating: NU5T-14G381-AB_1665525837000.TAR.GZ
[12/4/2022 1:04:02 AM] Downloaded: NU5T-14G381-AB_1665525837000.TAR.GZ
[12/4/2022 1:04:02 AM] Checking Existing File: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[12/4/2022 1:04:02 AM] Downloading: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[12/4/2022 1:07:38 AM] Validating: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[12/4/2022 1:07:46 AM] Downloaded: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[12/4/2022 1:07:46 AM] Checking Existing File: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[12/4/2022 1:07:46 AM] Downloading: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[12/4/2022 1:09:47 AM] Validating: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[12/4/2022 1:09:48 AM] Downloaded: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[12/4/2022 1:09:48 AM] Checking Existing File: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[12/4/2022 1:09:48 AM] Downloading: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[12/4/2022 1:13:41 AM] Validating: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[12/4/2022 1:13:43 AM] Downloaded: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[12/4/2022 1:13:43 AM] Checking Existing File: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[12/4/2022 1:13:43 AM] Downloading: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[12/4/2022 1:21:41 AM] Validating: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[12/4/2022 1:21:47 AM] Downloaded: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[12/4/2022 1:21:47 AM] Checking Existing File: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[12/4/2022 1:21:47 AM] Downloading: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[12/4/2022 1:27:01 AM] Validating: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[12/4/2022 1:27:07 AM] Downloaded: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[12/4/2022 1:27:07 AM] Checking Existing File: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[12/4/2022 1:27:07 AM] Downloading: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[12/4/2022 1:34:04 AM] Validating: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[12/4/2022 1:34:09 AM] Downloaded: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[12/4/2022 1:34:09 AM] Checking Existing File: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[12/4/2022 1:34:09 AM] Downloading: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[12/4/2022 1:37:42 AM] Validating: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[12/4/2022 1:37:44 AM] Downloaded: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[12/4/2022 1:37:44 AM] Checking Existing File: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[12/4/2022 1:37:44 AM] Downloading: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[12/4/2022 1:43:52 AM] Validating: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[12/4/2022 1:43:56 AM] Downloaded: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[12/4/2022 1:43:56 AM] Checking Existing File: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[12/4/2022 1:43:56 AM] Downloading: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[12/4/2022 1:49:46 AM] Validating: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[12/4/2022 1:49:52 AM] Downloaded: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[12/4/2022 1:49:52 AM] Checking Existing File: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[12/4/2022 1:49:52 AM] Downloading: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[12/4/2022 1:56:27 AM] Validating: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[12/4/2022 1:56:33 AM] Downloaded: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[12/4/2022 1:56:33 AM] Checking Existing File: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[12/4/2022 1:56:33 AM] Downloading: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[12/4/2022 2:01:16 AM] Validating: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[12/4/2022 2:01:24 AM] Downloaded: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[12/4/2022 2:01:24 AM] Checking Existing File: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[12/4/2022 2:01:24 AM] Downloading: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[12/4/2022 2:05:43 AM] Validating: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[12/4/2022 2:05:49 AM] Downloaded: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[12/4/2022 2:05:49 AM] Checking Existing File: 4U5T-14G424-CE_1644243346000.TAR.GZ
[12/4/2022 2:05:49 AM] Downloading: 4U5T-14G424-CE_1644243346000.TAR.GZ
[12/4/2022 2:05:49 AM] Validating: 4U5T-14G424-CE_1644243346000.TAR.GZ
[12/4/2022 2:05:49 AM] Downloaded: 4U5T-14G424-CE_1644243346000.TAR.GZ
[12/4/2022 2:05:49 AM] Preparing USB drive
[12/4/2022 2:05:49 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[12/4/2022 2:05:49 AM] Copying: 1u5t-14g386-cb.tar.gz
[12/4/2022 2:05:49 AM] Validating: 1u5t-14g386-cb.tar.gz
[12/4/2022 2:05:49 AM] Copied: 1u5t-14g386-cb.tar.gz
[12/4/2022 2:05:49 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/4/2022 2:05:49 AM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/4/2022 2:05:58 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/4/2022 2:06:01 AM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/4/2022 2:06:01 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/4/2022 2:06:01 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/4/2022 2:06:14 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/4/2022 2:06:19 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/4/2022 2:06:19 AM] Checking Existing File: NU5T-14G381-AB_1665525837000.TAR.GZ
[12/4/2022 2:06:19 AM] Copying: NU5T-14G381-AB_1665525837000.TAR.GZ
[12/4/2022 2:06:54 AM] Validating: NU5T-14G381-AB_1665525837000.TAR.GZ
[12/4/2022 2:07:02 AM] Copied: NU5T-14G381-AB_1665525837000.TAR.GZ
[12/4/2022 2:07:02 AM] Checking Existing File: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[12/4/2022 2:07:02 AM] Copying: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[12/4/2022 2:07:56 AM] Validating: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[12/4/2022 2:08:05 AM] Copied: 4U5T-14G421-CAE_1644006917000.TAR.GZ
[12/4/2022 2:08:05 AM] Checking Existing File: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[12/4/2022 2:08:05 AM] Copying: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[12/4/2022 2:08:32 AM] Validating: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[12/4/2022 2:08:36 AM] Copied: 4U5T-14G422-CCK_1644009966000.TAR.GZ
[12/4/2022 2:08:36 AM] Checking Existing File: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[12/4/2022 2:08:36 AM] Copying: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[12/4/2022 2:09:15 AM] Validating: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[12/4/2022 2:09:21 AM] Copied: 4U5T-14G422-CBK_1644010207000.TAR.GZ
[12/4/2022 2:09:21 AM] Checking Existing File: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[12/4/2022 2:09:21 AM] Copying: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[12/4/2022 2:10:28 AM] Validating: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[12/4/2022 2:10:38 AM] Copied: 4U5T-14G422-CAK_1644007869000.TAR.GZ
[12/4/2022 2:10:38 AM] Checking Existing File: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[12/4/2022 2:10:38 AM] Copying: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[12/4/2022 2:11:31 AM] Validating: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[12/4/2022 2:11:39 AM] Copied: 4U5T-14G421-CHE_1644007810000.TAR.GZ
[12/4/2022 2:11:39 AM] Checking Existing File: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[12/4/2022 2:11:39 AM] Copying: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[12/4/2022 2:12:37 AM] Validating: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[12/4/2022 2:12:46 AM] Copied: 4U5T-14G421-CGE_1644007746000.TAR.GZ
[12/4/2022 2:12:46 AM] Checking Existing File: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[12/4/2022 2:12:46 AM] Copying: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[12/4/2022 2:13:22 AM] Validating: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[12/4/2022 2:13:27 AM] Copied: 4U5T-14G421-CJE_1644007404000.TAR.GZ
[12/4/2022 2:13:27 AM] Checking Existing File: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[12/4/2022 2:13:27 AM] Copying: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[12/4/2022 2:14:23 AM] Validating: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[12/4/2022 2:14:32 AM] Copied: 4U5T-14G421-CFE_1644007219000.TAR.GZ
[12/4/2022 2:14:32 AM] Checking Existing File: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[12/4/2022 2:14:32 AM] Copying: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[12/4/2022 2:15:29 AM] Validating: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[12/4/2022 2:15:38 AM] Copied: 4U5T-14G421-CEE_1644007167000.TAR.GZ
[12/4/2022 2:15:38 AM] Checking Existing File: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[12/4/2022 2:15:38 AM] Copying: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[12/4/2022 2:16:46 AM] Validating: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[12/4/2022 2:16:58 AM] Copied: 4U5T-14G421-CDE_1644007104000.TAR.GZ
[12/4/2022 2:16:58 AM] Checking Existing File: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[12/4/2022 2:16:58 AM] Copying: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[12/4/2022 2:17:51 AM] Validating: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[12/4/2022 2:18:00 AM] Copied: 4U5T-14G421-CCE_1644007033000.TAR.GZ
[12/4/2022 2:18:00 AM] Checking Existing File: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[12/4/2022 2:18:00 AM] Copying: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[12/4/2022 2:19:00 AM] Validating: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[12/4/2022 2:19:08 AM] Copied: 4U5T-14G421-CBE_1644006981000.TAR.GZ
[12/4/2022 2:19:08 AM] Checking Existing File: 4U5T-14G424-CE_1644243346000.TAR.GZ
[12/4/2022 2:19:08 AM] Copying: 4U5T-14G424-CE_1644243346000.TAR.GZ
[12/4/2022 2:19:08 AM] Validating: 4U5T-14G424-CE_1644243346000.TAR.GZ
[12/4/2022 2:19:08 AM] Copied: 4U5T-14G424-CE_1644243346000.TAR.GZ
[12/4/2022 2:19:08 AM] Generating reformat.lst
[12/4/2022 2:19:08 AM] Generating autoinstall.lst
[12/4/2022 2:19:08 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
AsBuilt Data from old Sync 2 Module
Sync 2 Pre-Upgrade.abt (196 Bytes)
AsBuilt Data from Sync 3 module
Sync 3 AsBuilt Pre-Prog.abt (349 Bytes)
Also, when I set the climate strategy field to Europe, it starts working, except none of the buttons toggle neither does the temperature actually appear. When I increase the fan speed on screen the heat starts to come out like normal, but I can’t even see what fan speed I’m on.
I don’t have time to look through your AB settings on your Sync 3 module, but I can tell you all the problems your having are because of settings. If F1150Chief does not tell you what changes to make I can give you my AB settings when I have time.
The USB message will stop once you upgrade the USB hub.
@bill32399
Post your asbuilt, it will be more complete. Thanks.
I understand! Thanks for your input. I figured it was due to settings. I just couldn’t figure out which ones were causing the issues.
Thanks for your help as well.
I’ll try to get those APIM AB settings tonight. Very busy at work and all I usually wanna do is goto bed.
Of course, whenever you have time much appreciated. Thanks again.
My time also isn’t working. If I turn the radio on with the car off it works, but not when the car is running. You can click on the time and it’ll bring up the time configuration menu (shows the correct time), but not from the home screen. It just displays as —:—. Is this just another AsBuilt setting?
Yes.
Gotcha ok. I’m assuming @bill32399 also has a 2015 Explorer?
Yep.
I was able to fix the climate controls completely using an AsBuilt file from someone in the Discord server with a 2014 Explorer! I’ve also gotten back voice control and the seek button on the steering wheel.
So sorry man, I have been working nights everyday this whole week, 6 nights in a row so far. Sounds like you got it fixed though. 2014 should be the same as 15 settings wise. I think even the Calibrations are the same.
No problem! Yeah it was basically the same. I only tweaked a few minor things and it fixed my climate page completely.
