Run the APIM Interrogator Utility and post the results. Redact you VIN.
Hi ![]()
Here you go. Funny thing - sync3 updater couldn’t read the file. I got a promp to contact cyanlabs.
Strange…
Sync_WW7HB9JJ_xxxxxxx.xml (10,5 KB)
The log looks fine, no issues there except the Interrogator Utility did not collect some info. Not an APIM issue.
The installed files are:
1U5T-14G421-BAH
1U5T-14G421-BBH
1U5T-14G421-BGH
1U5T-14G421-BFH
5U5T-14G391-AR
4U5T-14G422-BCF
4U5T-14G423-AC
1U5T-14G658-AG
5U5T-14G381-EU
The storage space is below. There is plenty of free space on the unit.
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“1.1G” available=“892K”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“2.8G” available=“14M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“3.2G” available=“5.7M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“3.1G” available=“24M”/>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“3.6G” available=“35M”/>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“1.9G” available=“8.4M”/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total=“1003M” available=“21M”/>
<d2p1:PartitionHealth type="/fs/rwdata/" total=“1.2G” available=“982M”/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total=“35M” available=“35M”/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total=“90M” available=“90M”/>
<d2p1:PartitionHealth type="/fs/mp/" total=“1.4G” available=“132M”/>
<d2p1:PartitionHealth type="/fs/mp/resources" total=“71M” available=“476K”/>
<d2p1:PartitionHealth type="/fs/images/" total=“25G” available=“7.1G”/>
Did you convert the APIM and ACM asbuilt settings to EU? Can you post the APIM asbuilt?
nope, I got a faulty OBD cable, will do it in 2-3 days.
I need to change country code in APIM AsBuild and ACM (not sure what) i know that i can change dash language as well, i need to dig into this.
https://cyanlabs.net/fhub/apim-asbuilt-decoder/?filename=1650388284.xml
This will tell you what to change in the APIM and ACM.
Tutorial: Current EU Maps Installation on US Imported Vehicles - Ford / APIM (Sync 3) - CyanLabs Official Community
As for the IPC language change, this is likely 720-02-01 **xx-xxxx-xx. It will most likely be set to ‘03’ which is US English. It could also be one of these:
0D=NA English
0F=NA English
10=NA English
11=NA English
13=NA English
14=NA English
15=NA English
18=NA English
1C=NA English
1E=NA English
If you want to change the language for the IPC to Polish, you will need:
0E=Polish
You will also need to set the country code at 720-03-01 ****-xx.
Thanks! this is what i needed but…
this is sooo fcking frustrating. I have another cable. This one is visible through forscan but i can’t connect to vehicle.
I’m getting a bunch of errors:
Configuration tab shows:
Interface:
Type: FTDI #1:A50285BI, 500000 bps
Adapter: ELM327 v1.5
Min.delay: 3 ms ( Excellent)
Errors:
- CAN ERROR: 3 ( 6.1% )
Errors seem to differend each time but no 3 is the most common.
Any ideas? I tried on/off engine on/off radio and with connected battery charger. Voltage is showing in forscan and shows around 12v (with connected charger, bulk charging in progress - vehicle is not daily used)
Forscan version is v.2.3.47, port driver is updated, im using Windows XP.
The computer or program cannot detect the adapter…
Will try today on a different computer with forscan demo and update on situation ( comp i use is quite old, maybe thats the problem). There is some kind of connection with a car ( battery voltage shown).
Vitalij i dont understand. Check me o the file? I didn’t upload my files here ![]()
What adapter are you using? Forscan has 2 adapters they recommend, the others are hit and miss with issues.
Hi,
i use this one: Amazon.com
I have read somewhere that in order to read all the moduls i need adapter with HS/MS switch. vLinker doesn’t have one ![]()
Today i received vLinker cable and this time i managed to connect without any problems. Looks like forscan is very picky
Tommorrow i’ll have some fun with it and let ya all know how it goes ![]()
That is not recommended, it’s not supported by FORScan. It’s from China… Known problems with china clones of ELM327 - FORScan forum
The VLinker and OBDLink adapters are both compatible adapters and comply to J2534, which that one does not. There is no need for hard switches anymore, the software can do that for you and is much faster at it.
First thing…load the newest drivers from the website. Make sure you enable the checkbox for FORScan to check and update drivers if needed.
Hi, succes! ![]()
I manged to reprogram modules with forscan including dash and infotainment language. I also have navi directions in polish and other voice commands like set temp etc. Only thing that doesnt work at first glance is ‘find address’. It says in response that this function is not available because maps are still updating. It is probably related to this prompt mentioned before. Altrought i didn’t use my car. Maybe now after changes with forscan it needs couple of restarts to fully configure.
Hi, find address is working. System needed some time i guess. For now last thing which doesn’t work as i would like to are logos of radiostations. Now im seeing US logos instead of polish ones. Any ideas?
You would need to replace the ACM for an EU version.
