cinek
(cinek)
17 April 2022 16:57
1
Hi,
I have a FORD EXPLORER 2017 with maps and SYNC 3. Current version is 3.0 Build 20204. I’d like to upgrade to Sync 3.4 ad change maps to EU. I know that i can’t store all regions.
As far as i understood i can use updater and buy maps on site.
I have some doubts if it should be 2 step process or i can update whole system at once? I have read all the tutorials but i still don’t know should i change my car’s region before using updater? I don’t want to brick my system.
BR
Marcin
SaNdMaN
(SaNdMaN)
17 April 2022 17:18
2
The update itself it’s a single step, but first you must get the packages to be installed.
Once you do, you create a single USB and perform the upgrade.
But, there’s a catch: as described, you will also need to reprogram the APIM, so you will need forscan and a OBD2 scanner.
Installation and reprogramming need to happen for the NAV to work properly.
cinek
(cinek)
17 April 2022 18:59
4
Should i reprogram APIM before upgrade
or after?
cinek
(cinek)
18 April 2022 08:21
6
Ok thanks
Is there a tutorial which functions to change from US to EU with polish language in the dash and btw is there a polish voice commands available? From what i have watched it is not possible. Can you confirm?
And one more topic.
"USB hub not supported, please remove” error when upgradeing from Sync 3.0. should i upgrade to lets say 3.3 to aviod that error?
I do have android auto and carplay even now.
Polish is available in the EU voice file.
Android Auto will work, CarPlay will not with the old hub under Sync 3.2+. You can leave the hub if you do not use CP, but you will always get the error on startup.
cinek
(cinek)
18 April 2022 18:59
8
Ok, thats not good… I swe some threads about replacing procedure. Hmm my ford is from 2017 i hope it will be ok, if error occurs i will look for replacement
HU5Z-19A387-C (BLUE BACKLIGHTING) Ford (Wide 1 USB-A Port, w/Pass Through)
Interchange Part Number:
HU5T-14F014-AA, HU5T-14F014-AB, HU5T-14F014-AC, HU5Z-14F014-BB
2016-2019 Ford Mustang
2016-2019 Ford Focus
2016-2019 Ford Explorer
Media Hub, CarPlay Compatible - 2015-2020 Ford/Lincoln - SYNC 3 - Ford APIM - Docs - CyanLabs Official Community
cinek
(cinek)
19 April 2022 20:40
10
Thank you very much
I have my interrogation log. Guys can you look at it and see if everything is ok before i try to reflash it?
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance ” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2022-04-19” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>xxxxxxxxxxxxxxxxxx</p:VIN>
<p:RequestRole>
d2p1:Role CONSUMER</d2p1:Role>
d2p1:RoleSource OTA</d2p1:RoleSource>
d2p1:RoleDesc SYNC</d2p1:RoleDesc>
d2p1:RoleID OTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType/>
d2p1:Address 7D0</d2p1:Address>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:Response JR3T-14G381-AX</d2p1:Response>
d2p1:IsConfig false</d2p1:IsConfig>
</d2p1:DID>
d2p1:Response 484235542d3134473432312d4344000000000000000000004a5233542d3134473339312d434500000000000000000000484e31542d3134473432322d4341000000000000000000004a5233542d3134473432332d434200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
d2p1:Response 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
d2p1:Response 7715acf3</d2p1:Response>
</d2p1:DID>
d2p1:Response 715a054c</d2p1:Response>
</d2p1:DID>
d2p1:Response 2a2a05020c028900049a</d2p1:Response>
d2p1:IsConfig true</d2p1:IsConfig>
</d2p1:DID>
d2p1:Response 55530104c002008000000005</d2p1:Response>
</d2p1:DID>
d2p1:Response 0000000200</d2p1:Response>
</d2p1:DID>
d2p1:Response 010001000b0002</d2p1:Response>
</d2p1:DID>
d2p1:Response 1a2c1a2c2bfc</d2p1:Response>
</d2p1:DID>
d2p1:Response 80</d2p1:Response>
</d2p1:DID>
d2p1:Response 0a0033000000001770000056568c0088</d2p1:Response>
</d2p1:DID>
d2p1:Response DS-GB5T-14G371-CB</d2p1:Response>
</d2p1:DID>
d2p1:Response HB5T-14G380-BA</d2p1:Response>
</d2p1:DID>
d2p1:Response HB5T-14G371-CCA</d2p1:Response>
</d2p1:DID>
d2p1:Response GB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
d2p1:Response WW7HB9JJ</d2p1:Response>
</d2p1:DID>
d2p1:Response Blank</d2p1:Response>
</d2p1:DID>
d2p1:Response 03</d2p1:Response>
</d2p1:DID>
d2p1:Response GB5T-14G374-CB</d2p1:Response>
</d2p1:DID>
d2p1:Response </d2p1:Response>
</d2p1:DID>
d2p1:Response 7c:38:66:43:fb:39</d2p1:Response>
</d2p1:DID>
d2p1:Response 7c:38:66:43:fb:3a</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2022-04-19T19:05:18+00:00” RAM=“1074937856” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/fs/usb0/” total=“15G” available=“15G”/>
<d2p1:PartitionHealth type=“/fs/tmpfs/” total=“128M” available=“126M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.5G” available=“38M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“8.9G” available=“56M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.3G” available=“222M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“482M” available=“2.5M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/grace” total=“1.0G” available=“5.1M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1024M” available=“583M”/>
<d2p1:PartitionHealth type=“/fs/mp/” total=“1024M” available=“40M”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“26G” available=“8.8G”/>
d2p1:InstallationLog/
d2p1:SyncData 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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
You should be able to upgrade to 3.4 without an issue except for the hub, really.
cinek
(cinek)
20 April 2022 10:03
13
Reflash ok. Master reset performed. No USB hub error i hope it will not occure after APIM mod. Will observe
cinek
(cinek)
20 April 2022 14:03
14
Update: navi works but no voice commands. Sometimes i gry this prompt. Is it USB hub?
No that is the navigation still loading. Could you post your Syn3 Updater log file from the usb, please.
cinek
(cinek)
22 April 2022 14:24
16
HI, sorry i was out on a business trip. You mean this one?
log.txt (9,2 KB)
You have 5 map files and 1 Map Voice file installed, which with the rest of the Apps, System Voice, GN, etc. puts the APIM very close to full, with little space to process the normal operations, especially NAV. You will probably continue to get the message until you remove one of the map files. Remember you need to keep the first two, 1U5T-14G421-BAH and 1U5T-14G421-BBH.
You need to remove one of these from the installation and run the installation again for the maps:
1U5T-14G421-BEH - France, Andorra, Monaco, Switzerland
1U5T-14G421-BFH - Austria, Belgium, Czech Republic, Germany, Lichtenstein, Luxembourg, The Netherlands (Holland), Poland, Slovakia
1U5T-14G421-BGH - Albania, Bosnia & Hercegovina, Greece, Croatia, Montenegro, Serbia, Macedonia, Malta, Slovenia, San Marino, Turkey, Vatican, Italy
cinek
(cinek)
22 April 2022 19:13
18
Hmm, i understand that if i simply remove file 1U5T-14G421-BEH from the usb and stick it again it will reflash without this map and i should get rid of this. I do not need to use uploader and create uploader from the begining.
CyanLabs
(CyanLabs)
22 April 2022 19:15
19
you need to remove it from the LST file also
cinek
(cinek)
22 April 2022 19:32
20
Yes of course. I’ll let you know if that helps😀
cinek
(cinek)
23 April 2022 11:12
21
I did another reflash today. I had to downgrade first. Aaand nope, still getting this notification. Not always, i cant find any pattern. Maybe APIM modification will help. I have to order another OBD cable, one i got is faulty. My navi works but without voice info, from time to time im getting voice directions in some strange language ( some kind nordic one i guess?)…
