Sync 3-3.4 won’t update
Can some one help explain why my 2016 ford is saying indexing USB when I plug it in to update? I used cyanlabs and the link for the downloads an d instructions . Not sure why it’s not accepting the USB as an update ??
Old SYNC Version: 3
Did you not use Syn3Updater to create the media?
I had to follow the manual method because I have a Mac, could that be the issue?
Post a screenshot of the root of the USB drive
The autoinstall.lst file is not properly named, it has a (1)…
It should be simply autoinstall.lst…
Oh wow, ok just fixed that and it immediately started to update… not sure how that 1 got there … thanks a ton
You are welcome!
Probably, maybe, you downloaded it more than once, Windows does that as well…
Tell us how it goes., remember to perform a master reset once the upgrade is done.
Take care.
Make sense, and Will do!
Update:
worked like a charm! Thanks for all the help!
