Sync 3.4.22251 Ford Escape 2020 issue. Fault in APIM module B108E:4A-0B.
Hi Guys!
I have an issue with my Sync 3 in Ford Escape 2020 from USA. I am from Poland and i wanted to convert my sync to polish standard. I have made it by sync3 updater in automatioc mode. The protection of 2020 or above was switched on. During updating i had a MEM_ERR 01 or 03, i dont remeber. First i removed a gracenoted according to sync3 updater, next i install small pack of voices also according to sync3 updater, i still had a MEM_ERR. In last step i made a downgrade according to sync 3 updater in order to having a more space for update to polish standard (maps and voices). i know that USA APIM has a 32gb vs 64gb in EU APIM. Pack of update was good prepared with sync 3 updater (all required files and only pack of maps where is poland and only pack of voices where is polish). After last step (downgrade to having a free space for update) sync 3 made a restart and after the restar radio work ok but my display of sync 3 is still black and i have fault in apim module B108E:4A-0B. I was reading some topics about it and i know that driver for display in apim module is bad or isn’t present and it cause the problem. I was reading topic of Jaafar (If i good remember the name of user) where he has solved this problem.
Maybe someone has/had the same problem and has a solution for this. I need save my sync 3. Please Guys, help me.
Thank You in advance!
Old SYNC Version: 3.4.22251
MEM_ERR 01/03
Syn3 Updater Version: newest
I will attach it later in home.
Information on how to convert US Sync3 MY20 to PL/EU is here: https://www.fordescape.org/threads/how-to-change-sync3-my20-nav-us-pl-eu.123362/
Freeing space can be done with Navigation Data Remover after jailbreaking, so I did not use downgrading for this. I am not sure what state your Sync3 is in now. You can ask on forum.fordclubpolska.org (either Kuga or Audio/CB/GPS section) if someone has some advice or if someone can fix the APIM (like maybe “tedi_k”, for example).
