Sync 3.4.23188 - Feedback & Issues
That’s great to hear, thanks for taking the time to pop by with positive vibes.
Hello!
I have the latest upgrade for Ford Ecosport build in 2018, 3.4.23188.
With the last map upgraded F12.
There is other map or other version for my car? There was some rumors about the next map upgraded F13, but never seen these upgrade on Sync3.
And no other version beside 3.4.23188.
Something is happen or there is no other update? Advise please! Thanks!
So far F13 hasn’t been released by Ford
This thread is not for asking about future map updates. Please make a new thread if you need to.
@warlock12118 & @sameh_abbas , from the opening message for this thread is crystal clear this topic is for feedback & issues with this particular build
So your last messages had been deleted since they were not related to either feedback or issues, please do not do that in the future …
Installed without issue on 2016 Focus titanium. installed HU5Z-19A387-C module in just a few minutes and have CarPlay. Awesome… Using a belkin usb A to C with an Iphone 16 pro.
No issues. Thanks for your work!
Thanks for popping by with feedback.
All non thread relevant messages had been deleted. Refrain from doing so in the future.
3.4.23188 Still has the obligatory MP3/USB audio playback stutter due to processor overload. Not fixed yet
I wonder if that is a later model thing?
My 2017 model has over 2,000 MP3 USB songs loaded and I never have any stutter issues with version 3.4.23188
I’m sitting on more that that on mine, 139Gb just shy of 15K 320kbp MP3s
Works fine on a native 2020MY vehicle, 2014 Escape Ti that was an MFT update running a K series, and a 2018 Fusion Platinum running both the original J series APIM, and L series from an F150 and an N series.
Did you go into settings and turn off Automatic Updates and send system diagnostics?
Just FYI regarding updates
I installed 3.4.23188 in my 2019 Expedition when it first came out. Ford still thinks I have 3.0.20204 and offers me 3.0.23219. I’m assuming this is because my Ex is 5 years old.
Mine does not have that. It may very well be your USB drive or your mp3 files are too big.
  1. it’s never going to offer you 3.4.x as Ford does not support updating from 3.0.x to 3.4.x
  2. Even if a dealer hooks up with IDS, the Ford owner site will not show anything more than 3.0.x as that is what the car came with.
It has nothing to do with you USB or MP3 files, you’ve modified the car.
If you turn off automatic updates and wifi that will avoid possible confusion but your Ford profile will always ‘think’ you still have version 3.0.20204 and offer you their last update which is probably the final update from them for your model.
hey guys i tried 2 different files, and even went into forscan’s AIPM , i enabled my electronic stability control, lights illuminate on cluster start up, BUT, the button doesn’t work after this 3.4.23118 and tried the one verson before it same thing 3.4.23088 anyone run into this?? 2018 f150 504a lariat sync 3.0.20204
What does this have to do with this topic? if you are having asbuilt issues post in AsBuilt - CyanLabs Official Community
sorry i cant seem to be able to post anything there its locked i was just looking for some guidance for my traction control button not working
Been having problems with my traction con trol noit sure if its related to the sync 3.4 update i did recently, or if its a setting i changed in the forscan.
i did the service procedures:
-abs calibrate longitudinal senor calibration in my garage level ground. etc
-IMPA lane departure warning system camera calibration road test, (switched lanes once during test)
-adjusted wheel arch height since mines a 4" lift. oem setting are 1000mm and i changed it to 1066mm because that the new height
do i need to do other things? my traction control dash button isnt doing anything right now, and the truck feels off for the sensors, allowing allot of slipin the tires before it decides to kick in.
or should i just restoring modules?
So after being told this has nothing to do with this topic you than continue to talk about it. Start a new topic and you will get help. Don’t hijack the wrong thread.
