Sync 3.4.23188 - Feedback & Issues
Introduction
Sync 3.4.23188 has been found online and added to Syn3 Updater! thanks once again to @AuRoN
Important Notes
This release only updates the APP package
Rules
  • Do not reply to this thread with general issues that are not specific to 3.4.23188
  • If you notice a bug or change specific to this feature report it below
Failure to follow the above rules will result in your post either being moved (if moderators or myself are feeling generous) or deleted without prompt
To clarify, MEM_ERR’s, Missing Logos, LST_ERRS etc should not be posted here, make a new thread using this Support Link
Install Methods
Syn3 Updater
Quick Links
China : syn3updater://Region=CN;Release=3.4.23188
Europe: syn3updater://Region=EU;Release=3.4.23188
North America: syn3updater://Region=NA;Release=3.4.23188
Australia: syn3updater://Region=ANZ;Release=3.4.23188
ROW: syn3updater://Region=ROW;Release=3.4.23188
Manual Method
It’s also added to the manual method available at the below link
App Package URL
https://cyanlabs.net/fhub/sync3-apim-sw-db/?ivsu=NU5T-14G381-AD
SYNC 3 Common Issues and FAQ’s
Official Issues
TBC
Community Spotted Issues
TBC
Community Spotted Changes
  • Issue with RWDATA being fully fixed (Fixed SLOGS compression and purge)
Technical Information from FMods
Package Name: NU5T-14G381-AD
Epoch: 1689364279000
Major Version: 3.4
Build: 23188
Build Date: 2023-07-07
Package Date: 2023-07-14
Release Date: 2023-08-02
List of Changed files: https://pastebin.com/CDJJW9mN
Changes (based on diff):
  • Updated several libs, bin, and ifs
  • Fixed SLOGS compression and purge
Does JB works? WORKING (according to community members)
Well that installed without event, i had to master reset to get Gracenotes to populate its details (as expected), Radio Logo’s work on DAB and FM, all controls work, screen is responsive.
I noticed that when you hit a certain speed now and the nav is on auto zoom it is delayed about 5 seconds before it transitions. Anyone else confirm this?
good morning, does anyone know if this version has fixed music jumps from a flash drive or which version has it fixed??? thank you.
Could anyone tell me how long I should expect the 23188 update to take, keeping existing F12 maps please?
depends what you install, like 10 minutes for apps only.
Thanks for the quick reply.
Are you saying that I can select and install just the apps package to apply the bug fixes, and leave all the other options unselected? Do any of the other options need to be installed in tandem with the apps package?
Ich habe eben meinen 2019er Kuga mit dem Syn3updater auf die Version 23188 geupdatet. Hat ohne Probleme funktioniert. Vielen Dank fĂĽr das Super Tool.
I just updated my 2019 Kuga to version 23188 with the Syn3updater. Worked without any problems. Thank you for the great tool.
Version: 3.4.23088
Install Mode: Automatische Erkennung (autoinstall)
My20 Protection Enabled: Deaktivert / Nicht MY20
; CyanLabs Syn3Updater 2.11.10.0 Stable - Autoinstall Mode - Sync 3.4.23188 EU
Item1 = VOICE - 5U5T-14G391-AT_1660763323000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G391-AT_1660763323000.TAR.GZ
Item2 = GRACENOTES - 4U5T-14G423-AC_1615425645000.TAR.GZ
Open2 = SyncMyRide\4U5T-14G423-AC_1615425645000.TAR.GZ
Item3 = ENH_DAB - 1U5T-14G658-AH_1644006443000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G658-AH_1644006443000.TAR.GZ
FILES (4)
[06.08.2023 08:38:51] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: Vorhandene Karten beibehalten
[06.08.2023 08:38:51] Install Mode: Automatische Erkennung (autoinstall) Forced: False
[06.08.2023 08:38:51] MY20 Protection: Deaktivert / Nicht MY20
[06.08.2023 08:38:51] Formatting USB drive
[06.08.2023 08:38:51] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[06.08.2023 08:38:59] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06.08.2023 08:38:59] Downloading: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06.08.2023 08:41:33] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06.08.2023 08:41:38] Downloaded: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06.08.2023 08:41:38] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06.08.2023 08:41:38] Downloading: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06.08.2023 08:42:45] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06.08.2023 08:42:47] Downloaded: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06.08.2023 08:42:47] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06.08.2023 08:42:47] Downloading: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06.08.2023 08:42:53] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06.08.2023 08:42:53] Downloaded: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06.08.2023 08:42:53] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[06.08.2023 08:42:53] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[06.08.2023 08:44:17] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[06.08.2023 08:44:20] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[06.08.2023 08:44:20] Preparing USB drive
[06.08.2023 08:44:20] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06.08.2023 08:44:20] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06.08.2023 08:48:23] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06.08.2023 08:48:39] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06.08.2023 08:48:39] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06.08.2023 08:48:39] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06.08.2023 08:50:23] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06.08.2023 08:50:25] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06.08.2023 08:50:25] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06.08.2023 08:50:25] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06.08.2023 08:50:34] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06.08.2023 08:50:34] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06.08.2023 08:50:34] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[06.08.2023 08:50:34] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[06.08.2023 08:52:47] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[06.08.2023 08:52:51] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[06.08.2023 08:52:51] Generating Autoinstall.lst
[06.08.2023 08:52:51] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Due to having massive problems with a full rwdata partition, I really want to update to 23188 but when I tried to do a master reset before updating, it doesn’t work…
Shall I try to update my sync without doing a master reset? Any suggestions?
I had today the same issue.
My systems was always started with AM instead of DAB. And always switching back to english. Master reset was not working as its hang when proceeding with the reset. Update to 3.4.23188 ended with error: VER_ERRO8.
The system had 0 byte free (/fs/rwdata/ = 0 / 1.2g)
So I was already desperate I need to go to the dealer. But then…
On a Ford f150 forum I found the solution (for me). (https://www.f150forum.com/f118/sync-3-memory-issue-538739/index38/)
Blockquote
1 - Go to your iPhone system settings
2 - Gereral
3 - CarPlay
4 - My Car…Sync 3
5 - Customize
6 - Delete All Extra Added On Apps
7 - Turn vehicle ignition to the On accessories only position
8 - Connect iPhone to vehicle
9 - Go to the Ford Sync App on the vehicle screen
10 - Go to CarPlay and delete the All Phones Listed
11 - Go to General Settings within Sync 3…You should now be able to perform a Master Reset. Wait 5 to 10 mins for Sync to reboot be patient, screen goes black for a bit then will return the the Ford emblem, your software should now be back to normal.
The I did again the update to: 3.4.23188 this time with succes!
now a lot more space:
/fs/rwdata/ = 802M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 11G / 54G
Hope this helps!
updated latest build of ROW version, compass is not working…its freezes to north…
I installed Apps only.
There’s a minor issue. Nav voice prompts often have a very brief silent pause during a word. Never had that before.
Did a Master Reset, possible slight improvement but issue still there.
Should I reinstall Nav Voice, or everything?
Just updated the Sync 3 system to 3.4.23188. Didn’t find any problems.
Thank you for your work
Version: 3.4.22110
FILES (4)
[13.08.2023 09:14:17] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: Vorhandene Karten beibehalten
[13.08.2023 09:14:17] Install Mode: Automatische Erkennung (autoinstall) Forced: False
[13.08.2023 09:14:17] MY20 Protection: Deaktivert / Nicht MY20
[13.08.2023 09:14:17] Formatting USB drive
[13.08.2023 09:14:17] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[13.08.2023 09:14:26] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[13.08.2023 09:14:54] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[13.08.2023 09:14:54] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[13.08.2023 09:15:04] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[13.08.2023 09:15:04] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[13.08.2023 09:15:04] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[13.08.2023 09:15:05] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[13.08.2023 09:15:05] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[13.08.2023 09:17:24] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[13.08.2023 09:17:27] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[13.08.2023 09:17:27] Preparing USB drive
[13.08.2023 09:17:27] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[13.08.2023 09:17:27] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[13.08.2023 09:25:58] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[13.08.2023 09:26:03] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[13.08.2023 09:26:03] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[13.08.2023 09:26:03] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[13.08.2023 09:29:47] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[13.08.2023 09:29:49] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[13.08.2023 09:29:49] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[13.08.2023 09:29:49] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[13.08.2023 09:30:06] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[13.08.2023 09:30:06] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[13.08.2023 09:30:06] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[13.08.2023 09:30:06] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[13.08.2023 09:34:51] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[13.08.2023 09:34:53] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[13.08.2023 09:34:53] Generating Autoinstall.lst
[13.08.2023 09:34:53] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
A post was split to a new topic: GPS fix issue
A post was split to a new topic: MEM issues while trying to upgrade
Sorry. My original post recorded an issue with the apps only update to 23188, which caused voice stuttering.
The replies were non-specific and needed clarification, which I still have not achieved, as they told me roughly what to do, but not how to do it :upside_down_face:
Another user has reported success and no issues when installing everything except maps.
So I will reinstall via that method.
Maybe if you would do some reading before posting your messages would not be deleted…
I installed it to Focus 2015 without any issues. Thanks for the update.
Does anyone know if Ford will ever support third party cameras again? Unfortunately I can’t update anymore since 21194 because the camera on the back stays black.
And having to update and reinstall an old version every time is annoying.
