SYNC 3.4 Build 23188 - 2020 F150 (Build / sold date Oct 2019 - Dec 2019) MEM__ERR01
Yes
This file will theoretically work for you once you delete GN. You will need to rename it removing the NA22 I used to keep the files from getting confused.
NA22 autoinstall.lst (1.1 KB)
If you run into an issue with it because of free space restrictions, you can just cut it into 4 pieces and just use the Options = Autoinstall argument at the end of each one.
Sync_VYB810D4_____________25062.xml (10.8 KB)
Here is the latest Interrogator Log. It looks like on the APIM it is up with no issues. I also reloaded Gracenote back in.
If the file does not show everything, I am not sure how to get what we need.
Thanks for all the help the past two days!
Sorry, I’m late to the party…
Awesome that it worked, so yeah, the APIM is struggling with the amount of files it needs to process all at once.
And yes, you should continue selecting a few items at a time… You can try with 2 maps to see if that works, but maps are big, so I’m not sure…
You should cover all the files pending to install, that I believe are maps and nav-voices…
Also, since a package update was successful, you can try running the interrogator log again to see if more packages are now displayed… You can then compare that with the files Ford pushed your way to install the missing ones.
Apologies, I didn’t see the XML file you provided.
I’m on mobile, but these are the important bits:
  • 5gb of free space, which is good, you gained 1.1 GB
  • there are more packages listed, these are the installed packages (Sync3 itself may not be listed):
4U5T-14G424-CF
4U5T-14G421-CAF
4U5T-14G421-CBF
4U5T-14G421-CCF
4U5T-14G421-CEF
4U5T-14G421-CHF
4U5T-14G421-CJF
4U5T-14G422-CBF
5U5T-14G391-CS
So double check those with your original list…
Also, a tip: you can open that XML file with Syn3Updater, it will let you know what’s on it…
It looks like you are ok now, despite some files not being listed as installed. This might just be because you cannot clear the rwdata cache completely since you cannot reformat the unit. Honestly, if it is now working properly with no issues, this is likely the best you will get without reformat. (Again, you can’t use the Ford reformat tools on this unit.)
This is listed as installed in the xml.
NU5T-14G381-AD
4U5T-14G424-CF
4U5T-14G421-CAF
4U5T-14G421-CBF
4U5T-14G421-CCF
4U5T-14G421-CEF
4U5T-14G421-CHF
4U5T-14G421-CJF
4U5T-14G422-CBF
5U5T-14G391-CS
This looks correct…
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.6G” available=“12M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.4G” available=“36K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.5G” available=“12M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.3G” available=“12M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“982M” available=“2.9M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.3G” available=“8.3M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.7G” available=“16M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.7G” available=“17M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.3G” available=“6.2M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.6G” available=“15M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.1G” available=“10M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“2.6G” available=“24M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“465M” available=“3.2M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“639M”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“25G” available=“5.0G”/>
Good job…!
Just as a note you can however jailbreak and install the modded reformat tool if desired, check fmods (google) for further information on that.
