Sync 3.4 - Carplay GPS (Apple, Waze and Google) NO Audio guidance
Hello,
I’ve been running Sync 3.4 on my F150 2016 Lariat, everything works grate, except the audio guidance for the Apple CarPlay GPS. Tried Google, Waze and Apple Maps, some times the system will speak only partial guidance. Audio from Siri and music works just fine.
Any suggestions? Thanks
Install Type: OEM Replacement
Old SYNC Version: 3.0
Does the audio through Apple CarPlay work at all? This seems to be the common factor. Is the issue only when using a phone connected via USB? Or is the same issue present with BT?
Google shows a lot of problems and solutions for this… no audio thru carplay - Google Search
