Sync 3.4 navigation fault
What is your SYNC Region? usa
What is your current SYNC Version? 3.420351
Do you have Navigation? yes
error code : pkg_erro4
โ€ฆ
CYANLABS - SYN3 UPDATER - V2.4.2.0
Branch: Release
Operating System: Microsoft Windows 7 Ultimate  ()
Version: 3.4.20282
Region: ROW
Mode: reformat FORCED
Model: Kingston DataTraveler 3.0 USB Device 28.8GB
GRACENOTES=4U5T-14G423-FB_1598637803000.TAR.GZ
APPS=5U5T-14G381-EM_1611967752000.TAR.GZ
VOICE=5U5T-14G391-FN_1598637717000.TAR.GZ
MAP=4U5T-14G421-FAH_1598637879000.TAR.GZ
MAP_LICENSE=4U5T-14G424-FAH_1598638505000.TAR.GZ
; CyanLabs Syn3Updater 2.x - reformat Mode - Sync 3.4.20351 ROW
FILES (7)
4U5T-14G423-FB_1598637803000.TAR.GZ (919.3MB)
5U5T-14G391-FN_1598637717000.TAR.GZ (1.4GB)
4U5T-14G421-FAH_1598637879000.TAR.GZ (4.9GB)
4U5T-14G424-FAH_1598638505000.TAR.GZ (1.7KB)
[13/03/2021 01:00:13 ู…] Selected Region: ROW - Release: Sync 3.4.20351 - Map Version: 2019 Q4 - ROW
[13/03/2021 01:00:13 ู…] Install Mode: reformat
[13/03/2021 01:00:13 ู…] Checking Existing File: 1u5t-14g386-cb.tar.gz
[13/03/2021 01:00:13 ู…] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[13/03/2021 01:00:13 ู…] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[13/03/2021 01:00:13 ู…] Validated: 1U5T-14G658-AF_1598633324000.TAR.GZ (Skipping Download)
[13/03/2021 01:00:13 ู…] Checking Existing File: 4U5T-14G423-FB_1598637803000.TAR.GZ
[13/03/2021 01:00:16 ู…] Validated: 4U5T-14G423-FB_1598637803000.TAR.GZ (Skipping Download)
[13/03/2021 01:00:16 ู…] Checking Existing File: 5U5T-14G381-EM_1611967752000.TAR.GZ
[13/03/2021 01:00:18 ู…] Validated: 5U5T-14G381-EM_1611967752000.TAR.GZ (Skipping Download)
[13/03/2021 01:00:18 ู…] Checking Existing File: 5U5T-14G391-FN_1598637717000.TAR.GZ
[13/03/2021 01:00:23 ู…] Validated: 5U5T-14G391-FN_1598637717000.TAR.GZ (Skipping Download)
[13/03/2021 01:00:23 ู…] Checking Existing File: 4U5T-14G421-FAH_1598637879000.TAR.GZ
[13/03/2021 01:01:21 ู…] Validated: 4U5T-14G421-FAH_1598637879000.TAR.GZ (Skipping Download)
[13/03/2021 01:01:21 ู…] Checking Existing File: 4U5T-14G424-FAH_1598638505000.TAR.GZ
[13/03/2021 01:01:21 ู…] Validated: 4U5T-14G424-FAH_1598638505000.TAR.GZ (Skipping Download)
[13/03/2021 01:01:21 ู…] Preparing USB drive
[13/03/2021 01:01:21 ู…] Formatting USB drive
[13/03/2021 01:01:21 ู…] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[13/03/2021 01:01:29 ู…] Generating reformat.lst
[13/03/2021 01:01:29 ู…] Generating autoinstall.lst
[13/03/2021 01:01:29 ู…] Checking Existing File: 1u5t-14g386-cb.tar.gz
[13/03/2021 01:01:29 ู…] Copying: 1u5t-14g386-cb.tar.gz
[13/03/2021 01:01:30 ู…] Validating: 1u5t-14g386-cb.tar.gz
[13/03/2021 01:01:30 ู…] Copied: 1u5t-14g386-cb.tar.gz
[13/03/2021 01:01:30 ู…] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[13/03/2021 01:01:30 ู…] Copying: 1U5T-14G658-AF_1598633324000.TAR.GZ
[13/03/2021 01:01:40 ู…] Validating: 1U5T-14G658-AF_1598633324000.TAR.GZ
[13/03/2021 01:01:40 ู…] Copied: 1U5T-14G658-AF_1598633324000.TAR.GZ
[13/03/2021 01:01:40 ู…] Checking Existing File: 4U5T-14G423-FB_1598637803000.TAR.GZ
[13/03/2021 01:01:40 ู…] Copying: 4U5T-14G423-FB_1598637803000.TAR.GZ
[13/03/2021 01:03:56 ู…] Validating: 4U5T-14G423-FB_1598637803000.TAR.GZ
[13/03/2021 01:03:58 ู…] Copied: 4U5T-14G423-FB_1598637803000.TAR.GZ
[13/03/2021 01:03:58 ู…] Checking Existing File: 5U5T-14G381-EM_1611967752000.TAR.GZ
[13/03/2021 01:03:58 ู…] Copying: 5U5T-14G381-EM_1611967752000.TAR.GZ
[13/03/2021 01:06:07 ู…] Validating: 5U5T-14G381-EM_1611967752000.TAR.GZ
[13/03/2021 01:06:09 ู…] Copied: 5U5T-14G381-EM_1611967752000.TAR.GZ
[13/03/2021 01:06:09 ู…] Checking Existing File: 5U5T-14G391-FN_1598637717000.TAR.GZ
[13/03/2021 01:06:09 ู…] Copying: 5U5T-14G391-FN_1598637717000.TAR.GZ
[13/03/2021 01:09:39 ู…] Validating: 5U5T-14G391-FN_1598637717000.TAR.GZ
[13/03/2021 01:09:42 ู…] Copied: 5U5T-14G391-FN_1598637717000.TAR.GZ
[13/03/2021 01:09:42 ู…] Checking Existing File: 4U5T-14G421-FAH_1598637879000.TAR.GZ
[13/03/2021 01:09:42 ู…] Copying: 4U5T-14G421-FAH_1598637879000.TAR.GZ
[13/03/2021 01:22:27 ู…] Validating: 4U5T-14G421-FAH_1598637879000.TAR.GZ
[13/03/2021 01:22:39 ู…] Copied: 4U5T-14G421-FAH_1598637879000.TAR.GZ
[13/03/2021 01:22:39 ู…] Checking Existing File: 4U5T-14G424-FAH_1598638505000.TAR.GZ
[13/03/2021 01:22:39 ู…] Copying: 4U5T-14G424-FAH_1598638505000.TAR.GZ
[13/03/2021 01:22:39 ู…] Validating: 4U5T-14G424-FAH_1598638505000.TAR.GZ
[13/03/2021 01:22:39 ู…] Copied: 4U5T-14G424-FAH_1598638505000.TAR.GZ
[13/03/2021 01:22:39 ู…] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
โ€ฆ
navigation fault.
navigation is not functioning property
You are configuring the app wrong.
You say your car is NA, but selected ROW in the tool while creating the USB, and I think you didnโ€™t select maps. Also, you are forcing REFORMAT, why?.
Recreate the USB with proper settings and let the app decide whatโ€™s best.
it was sync 3.0 so i choose reformat and row for middle east map
As said before, do not force anything unless you know what you are doing. Besides that configuration does not reflect what you just said (that it was a 3.0)
Also, you said the car was USA, and now you are trying to make it ROW.
CyanLabs does not support changing regions
Thereโ€™s information, but it is not supported.
can i do any thing now or not
Like sandman said, cyanlabs does not support changing regions, so if its not a big deal, I suggest you change it back to NA and to not force the reformat and reinstall.
