My car is a U.S. Spec 2016 Ford Taurus Limited.
I’ve tried to update my Sync 3.0 to Sync 3.4 using the tutorial. I wanted to download the ROW version since that’s where I live currently. I’m now stuck at the screen where it says “Starting Update…” for the past 30 minutes and nothing changed. Is there a solution to this please?
Cut power to the sync unit, turn off car and open door for a few minutes, if that doesn’t work disconnect the battery. then connect it againa, turn on car and the process should start. sometimes it hangs at that step
