Hi, I could use an asbuilt configuration of the C-max Hybrid sync3 -APIM
I upgraded from sync2 to sync3, and can’t get it cofigurated properly…
Help would be welcome
Thanks in advance
Hi Thierry,
Here is a Sync 3 asbuilt for a 2018 C-Max Titanium Hybrid. It’s NA but should be applicable.
7D0-01-01
232861038008
7D0-01-02
220A16000A26
7D0-02-01
55530106C049
7D0-02-02
82000000005D
7D0-02-03
0005E1
7D0-03-01
0001000000DC
7D0-04-01
010004E104C6
7D0-04-02
0003E0
7D0-05-01
17A21798286D
7D0-05-02
BE9C
7D0-06-01
805E
7D0-07-01
110433000027
7D0-07-02
000006820068
7D0-07-03
0004306A007F
7D0-07-04
6446
7D0-08-01
0000000000E0
7D0-08-02
0000000000E1
thank you
The situation is as follows : have loaded the above as-built. There is no time display and no climate control. Climate control not on the screen, is this supposed to be like that? In the meantime I have found 2 extra VINs of C-Max hybrids, they all give the same picture … I have Sirius instead of DAB, but that’s because it is NA … It turns out that climate control is not possible with the c-max, that it can only be operated manually with the buttons, is this correct?
Hi Thierry,
1st is what architecture is set up on APIM?
2nd are you doing on bech or on car? As APIM needs to communicate with FCIM in order to get Climate, for the clock is responsible IPC unit.
Just a remark that CMAX are using C1MCA architecture and not CGEA as far as I know.
Cheers ![]()
Climate control was not equipped for the APIM in C1CMA vehicles. Later versions were different.
Yes, this is true.
So, just for the record…i assume c-max and focus are related and thus have great similarities in terms of as-built settings? Or am I wrong? And that the focus from 2015 until the facelift (3.5) has the C1MCA architecture and from the facelift the CGEA? Assuming this is correct and I want to put sync3 in a 2015/2016 cmax/focus, I have to set C1MCA… .not CGEA.
Another question: what is PDC architecture?
You are correct, sir.
Parking Distance Control
You will need PDCA CIMCA.
