Sync 3 clock not working
Hello,
I just updated to a Sync 3 in my 2013 F150 and with the Cyanlabs update. My only issue I’m having now is that my clock won’t set to the correct time. I do not have a GPS cable and would like to not need one. I assume I can go through the APIM via FORScan, but was hoping for any help or suggestions.
Thanks
SYNC Region: USA
Old SYNC Version: 2.0.16074
NA
Syn3 Updater Version: Syn3Updater_Installer
; CyanLabs Syn3Updater 2.13.0.0 Stable - reformat  Mode - Sync 3.4.23188 NA
Sync3 requires a GPS, it pulls its time hack from there.
The cheap one listed in F150Chief’s thread is only like $13 USD.
You could try and change the Clock-Master ASBuilt value (7D0-01-01: xx**-xxxx-xxxx) of your Sync 3 APIM into IPC or BCM.
