it appears this topic has been broached before but since this forum has a 14 day threads closer(something i’ve never seen before), i’m statrting a new thread.
I recently purchased a 2016 Ford Flex SEL AWD with a Sync 3 1.0 system. I sucessfully updated it to 3.0 build 23219 via ford.com. Some searching led me to this site which appears to be able to update it to 3.4 build 23188 but more importantly up date maps for the nav. I began the process and the warning screen came up suggesting i run the interogator to confirm I’m not going to brick the APIM. The carfax states that in Febuary 2020, the radio was removed, it does not state the reason for it being removed or whether anything was replaced or repaired.
So i loaded the interogator onto my USB key, stuck it in the USB plug in the center console and waited… the instructions said to wait a few minute for it to finish… an hour later it was still “updating”. shut the car off and turned it back on and it gave me “not enough space or will not work with this version” error. Left the usb in over night and while driving around the next day it “completed” told me i could remove the usb key and it rebooted the system.
I stuck the USB key back in my computer and attempted to load the “xml” file from the sync3 folder. It said that it recognized the version but it contained an unexpected output and couldn’t confirm the configuration of the APIM and to post the log here and ask for help so here i am.
Old SYNC Version: 3.0.23219
unexted output, unable to confirm configuration of APIM
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2005-09-01" xsi:schemaLocation="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0 ModuleSnapshot.xsd">
<p:VIN>2FMHK6C82GBA01575</p:VIN>
<p:RequestRole>
</p:RequestRole>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>JR3T-14G381-AY</d2p1:Response>
</d2p1:DID>
<d2p1:Response>4a5233542d3134473339312d434500000000000000000000474235542d3134473432322d434a000000000000000000004a5233542d3134473432332d434200000000000000000000474235542d3134473432312d434a00000000000000000000474235542d3134473432342d434800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>WUCN022F</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>68:c9:0b:e2:f0:dd</d2p1:Response>
</d2p1:DID>
<d2p1:Response>68:c9:0b:e2:f0:de</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2005-09-01T17:54:42+00:00" RAM="1234567" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/usb0/" total="1000G" available="1000G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
