SYNC 3 LATEST UPDATE. BASS TREBLE MIDD STUCK ON MAXIMUM
I saw someone had this issue a few months ago but i did not see a solution. does anyone have a solution to this?
just installed sync 3 and updated to the latest version.
Old SYNC Version: 2
Version: 1.0.15139
; CyanLabs Syn3Updater 2.12.5.0 Stable - reformat  Mode - Sync 3.4.23188 NA
FILES (5)
[1/25/2024 6:54:16 PM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[1/25/2024 6:54:16 PM] Install Mode: Auto-Detect (reformat) Forced: False
[1/25/2024 6:54:16 PM] MY20 Protection: Auto-Detect
[1/25/2024 6:54:16 PM] Formatting USB drive
[1/25/2024 6:54:17 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[1/25/2024 6:54:24 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[1/25/2024 6:54:24 PM] Downloading: 1u5t-14g386-cb.tar.gz
[1/25/2024 6:54:25 PM] Validating: 1u5t-14g386-cb.tar.gz
[1/25/2024 6:54:25 PM] Downloaded: 1u5t-14g386-cb.tar.gz
[1/25/2024 6:54:25 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/25/2024 6:54:25 PM] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/25/2024 6:54:25 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/25/2024 6:54:25 PM] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/25/2024 6:54:25 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/25/2024 6:54:25 PM] Downloading: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/25/2024 6:54:41 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/25/2024 6:54:42 PM] Downloaded: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/25/2024 6:54:42 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/25/2024 6:54:42 PM] Downloading: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/25/2024 6:55:10 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/25/2024 6:55:11 PM] Downloaded: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/25/2024 6:55:11 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/25/2024 6:55:11 PM] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/25/2024 6:56:00 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/25/2024 6:56:02 PM] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/25/2024 6:56:02 PM] Preparing USB drive
[1/25/2024 6:56:02 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[1/25/2024 6:56:02 PM] Copying: 1u5t-14g386-cb.tar.gz
[1/25/2024 6:56:02 PM] Validating: 1u5t-14g386-cb.tar.gz
[1/25/2024 6:56:02 PM] Copied: 1u5t-14g386-cb.tar.gz
[1/25/2024 6:56:02 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/25/2024 6:56:02 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/25/2024 6:56:03 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/25/2024 6:56:03 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/25/2024 6:56:03 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/25/2024 6:56:03 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/25/2024 6:56:37 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/25/2024 6:56:38 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[1/25/2024 6:56:38 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/25/2024 6:56:38 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/25/2024 6:57:29 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/25/2024 6:57:30 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[1/25/2024 6:57:30 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/25/2024 6:57:30 PM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/25/2024 6:58:47 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/25/2024 6:58:49 PM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/25/2024 6:58:49 PM] Generating reformat.lst
[1/25/2024 6:58:49 PM] Generating autoinstall.lst
[1/25/2024 6:58:49 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Your APIM module is looking for a DSP.
Very first digit of the APIM programming
7D0-01-01 X***--
Change the X to one of the following depending on how your vehicle is set up.
0 = No DSP No SiriusXM
2 = No DSP with SiriusXM
So its the searching for a DSP causing this??
After just reading on another forumn someone said it was the (TVK) type of volume knob… my car had a rotary knob but the donor radio came from a car with a horizontal knob. do you think this could be an issue as well?
No, it’s the DSP search issue I mentioned above.
Horizontal/Rotary Volume display has nothing to do with it.
perfect. thanks for the help. my obd 2 for FORscan will be here sunday. i’ll try that out
