Thank you for the report, I can’t download it either from the link (I’m using Windows).
We will look into that.
This is the recommended path, since Syn3updater will not only create everything for you, but also validate files to ensure they have been properly downloaded/processed.
It does not really matter you started the manual process, since the process itself it’s the same.
So even though I started the manual process, and the console is waiting on that file, can I just begin again using the auto Syn3updater? I’m just paranoid about bricking anything.
Is the screen the Mustang car with a progress bar at the bottom?.
If so, that’s the reformat phase, so yes, it will be just fine.
Just make sure to configure syn3updater accordingly, that is, 3.3.xxx as current build.
It will create a reformat USB.
The link on my DB is not HTTPS if you are trying to connect via HTTPS it WILL fail, this is likely your browser or something called “HSTS” you will need to force HTTP or clear your HSTS settings in your browser.
Sure. To avoid downloading everything again, once you install syn3updater and select a download location for the files, copy the already downloaded files into that folder before starting the process.
That way, Syn3updater won’t download them again, it will just verify they are ok.
