SYNC 3 S-MAX 2017 / Sync Model 2021 Update from 3.0 to 3.4
I would like to update my Sync 3 from 3.0 to 3.4… However, the sync was replaced in 2021 and Sync3Updater says not possible. What options do I have?
Install Type: OEM Replacement
Old SYNC Version: 3.0.2319
Sync3Updater says it is not possible to read the USB stick
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2024-11-26" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
  <p:VIN>WF0JXXWPCJHR72901</p:VIN>
  <p:RequestRole>
  </p:RequestRole>
  <p:BroadcastDTCType/>
    <d2p1:ECUAcronym name="APIM">
      <d2p1:State>
            <d2p1:Response>JR3T-14G381-AY</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>4a5233542d3134473432312d4246000000000000000000004a5233542d3134473339312d4145000000000000000000004a5233542d3134473432322d4245000000000000000000004a5233542d3134473432332d414200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>f8c33b15</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>e75863c0</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>0a6a059a1302ee4206c2</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>474d0104c00b488000000000</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>0200000000</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>01001b00260107</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>1ba318b02bd0</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>08003300000000186a00005656750070</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>DS-HB5T-14G371-CA</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>HL1T-14G380-CC</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>JR3T-14G371-FJG</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>HB5T-14G375-FA</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>W38E6QRB</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>HB5T-14G374-CA</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>08:04:b4:f0:13:63</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>08:04:b4:f0:13:64</d2p1:Response>
          </d2p1:DID>
        </d2p1:Gateway>
      </d2p1:State>
    </d2p1:ECUAcronym>
    <d2p1:AdditionalAttributes logGeneratedDateTime="2024-11-26T17:11:19+00:00" RAM="947662848" vmcuVersion="Vector_VMCU_02.02.20">
      <d2p1:PartitionHealth type="/fs/usb0/" total="29G" available="29G"/>
      <d2p1:PartitionHealth type="/fs/tmpfs/" total="128M" available="127M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="5.7M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="21G" available="35M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="17G" available="46M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="1.9G" available="7.6M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/grace" total="1.0G" available="6.1M"/>
      <d2p1:PartitionHealth type="/fs/rwdata/" total="1024M" available="909M"/>
      <d2p1:PartitionHealth type="/fs/mp/" total="1024M" available="40M"/>
      <d2p1:PartitionHealth type="/fs/images/" total="56G" available="12G"/>
      <d2p1:InstallationLog/>
      <d2p1:SyncData>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</d2p1:SyncData>
    </d2p1:AdditionalAttributes>
  </p:Node>
</p:OTAModuleSnapShot>
Is it your PC saying “it is not possible to read the USB stick” If so use a different USB stick.
Your only option is to jailbreak the unit and use FMODS’ universal reformat package that can handle MY20 hardware.
:warning: DO NOT REFORMAT IT VIA SYN3UPDATER :warning:
