Sync 3 screen is very dim
Hello,
I have recently installed a new sync 3 APIM and screen to upgrafe from the sunc 2 that was installed from the factory.
After installing the parts the system works i have programmed it with forscan to match my vehicle everything that i want working works.
The only problem i have is that the screen is very dim, i can change the brightness in the options but that does very little.
I can see that the screen brightens and darkens a little when is use this option.
i have tried changing the illumination strategy in forscan to B but it did not help.
the part are oem ford sourced from ebay.
Is there anybody that had the same issue and can help me?
Kind regards,
I have been scouring this forum and the internet the past few days but to no luck.
Old SYNC Version: .
New SYNC Version: .
Syn3 Updater Version: .
I assume the one above is the one you changed?
Have you looked at this?
CGEA1.3+ Illumination Strategy (CGEAIS)
Illumination Change Step/Gradual (ICSG)
i did look ath the FAQ i wil try the other option you said
thanks for the fast reply
Posting your as-built would help.
i will pull it from the car and post it
WF05XXGCC5GC68520_APIM_20230801_215331.abt (495 Bytes)
this is my current asbuilt.
i dont know if the file is good or do you want a screenshot?
I’m not at a pc currently so can’t really look in to it myself currently, file should be fine.
Seems i never got back to this post, @ludzervaatstra did you get your issues solved?
Yes it turns out the screen itself was bad replaced it for another one and it was fixed.
Thanks for the update, my apologies for not replying
