SYNC 3 shows wrong outside temperature (-5), cant update HW JR3T-14G371-FFB (SW 3.0.18025)
No any errors for temp sensors (only ===PCM DTC P06DF:00-2C===)
Forscan shows normal temperatures from sensors
APIM -
HW: JR3T-14G371-FFB
calibration1: JR3T-14G371-FJG
strategy: HB5T-14G374-CA
calibration2: HB5T-14G375-FA
VIN: WF0AXXWPMAJA29569
Try to update but afraid of MY20/reformat issue on HW JR3T-14G371-FFB
but due to chart in documentation no change to upgrade in autoinstall mode
Install Type: Unknown
Old SYNC Version: 3.0.18025
INSTL_ERR11 (autoinstall mode)
when check HW JR3T-14G371-FFB on SYNC 3 APIM Hardware Database - CyanLabs it shows 20MY what reason to use autoinstall even it not work for 3.0
but if database shows what SYNC with HW JR3T-14G371-FFB has SW 3.0.18025
Interrogator log
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2024-06-19" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>WF0AXXWPMAJA29569</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>JR3T-14G381-AL</d2p1:Response>
</d2p1:DID>
<d2p1:Response>4a5233542d3134473432322d424300000000000000000000315535542d3134473432342d424d000000000000000000004a5233542d3134473432312d4243000000000000000000004a5233542d3134473432332d4141000000000000000000004a5233542d3134473339312d414400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>d83794af</d2p1:Response>
</d2p1:DID>
<d2p1:Response>dc94b388</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0968459290022e570002</d2p1:Response>
</d2p1:DID>
<d2p1:Response>474d01044002480000001005</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0400010200</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01001c01250001</d2p1:Response>
</d2p1:DID>
<d2p1:Response>18061810295f</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>17003b0000000000fa00000430750057</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-HB5T-14G371-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HL1T-14G380-CB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>JR3T-14G371-FFB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HB5T-14G375-FA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>LXB101GY</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>HB5T-14G374-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response>fc:69:47:cf:76:86</d2p1:Response>
</d2p1:DID>
<d2p1:Response>fc:69:47:cf:76:87</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2024-06-19T18:43:31+00:00" RAM="950706176" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/usb0/" total="7.4G" available="7.4G"/>
<d2p1:PartitionHealth type="/fs/tmpfs/" total="128M" available="127M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="3.2M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="18G" available="129M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="16G" available="867M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.8G" available="93M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="1.0G" available="6.1M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1024M" available="671M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1024M" available="173M"/>
<d2p1:PartitionHealth type="/fs/images/" total="55G" available="15G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot
Operating System: Майкрософт Windows 10 Pro (2009)
Version: 3.0.18025
Install Mode: autoinstall (autoinstall)
Install Mode Overridden: True
My20 Protection Enabled: Отключено / не MY20
Model: USB DISK 2.0 USB Device
; CyanLabs Syn3Updater 2.12.5.0 Stable - Autoinstall FORCED Mode - Sync 3.4.23188 EU
Item2 = VOICE - 5U5T-14G391-AT_1660763323000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-AT_1660763323000.TAR.GZ
Item3 = APPS - NU5T-14G381-AD_1689364279000.TAR.GZ
Open3 = SyncMyRide\NU5T-14G381-AD_1689364279000.TAR.GZ
FILES (3)
[19.06.2024 19:03:25] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: APIM без навигации
[19.06.2024 19:03:25] Install Mode: autoinstall (autoinstall) Forced: True
[19.06.2024 19:03:25] MY20 Protection: Отключено / не MY20
[19.06.2024 19:03:25] Formatting USB drive
[19.06.2024 19:03:25] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[19.06.2024 19:03:36] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[19.06.2024 19:03:36] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[19.06.2024 19:03:36] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19.06.2024 19:03:43] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[19.06.2024 19:03:43] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[19.06.2024 19:03:47] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[19.06.2024 19:03:47] Preparing USB drive
[19.06.2024 19:03:47] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[19.06.2024 19:03:47] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[19.06.2024 19:03:47] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[19.06.2024 19:03:47] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[19.06.2024 19:03:47] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19.06.2024 19:03:47] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19.06.2024 19:06:21] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19.06.2024 19:07:47] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[19.06.2024 19:07:47] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[19.06.2024 19:07:47] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[19.06.2024 19:09:14] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[19.06.2024 19:10:02] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[19.06.2024 19:10:02] Generating Autoinstall.lst
[19.06.2024 19:10:02] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Wrong outside temp can just be a problem with the ambient air temp sensor behind the front bumper cover.
It will only throw a code on open, it has no way of knowing that the real temp is 20º C while it thinks its 18ºC, Sync3 only shows what its sent via the BCM/PCM.
I have that same issue with my 2017 Escape. My Sync always displays the temperature as 2 to 5 degrees (Farenheit) warmer than the actual air temperature. It’s usually around 2 degrees (F) off in the summer and 4 or 5 degrees (F) off in the winter. To me that’s not a big deal and I don’t worry about it.
