Hello,
A little background information to explain where and why I have this issue.
I retired in July 2022 and so lost the use of company vehicle, so in October 2022 I purchased a 2017 Ford Focus Titanium X 1.5TDCi with Sync 3 installed, as far as I am aware all parts are original.
The only issue I had was that the Navigation fault pop up was a regular occurrence, sometime it reset itself after key cycle, I found the most convenient way to reset through the Test Settings (Remove Navigation Fault) in the hidden menu (Bezel Diagnostics). To try and correct this fault I downloaded the latest software from the Ford website and installed into the vehicle.
Software Version 2.2 Build 16280 to Version 3.0 Build 20204
Gracenote Version 1.1.1.794 to Version 1.1.11127
Maps Version EU4.15 Version F10.
Following this update I have only had 2 or 3 Navigation fault errors in the last 4 months. Then one day in late February, the Nav fault was continuous, the reset lasted a matter of minutes until the pop up Nav Fault occurred again. I opened the hidden menu and went into the Test Settings Screen to check satellite positions and they took a long time to load up, I did not have as many satellites as normal and there were no ID tags attached to the satellites that did show up. In my frustration I moved all the slide switches across to the on position on the test setting screen, then when I tired to slide them back to the off position, two of the parameters were locked in the on position (Enable GNNS sensor logging and Enable HIP Logging ).
When I checked the satellite positions again there were none, in addition the F10 map version was missing from the about sync screen. The home page on Sync 3 showed Navigation fault, when cleared the loading maps message and the blue loading circle appeared, but the maps never loaded, the blue circle just continued spinning. When the Nav button was pressed nothing happened, the Nav screen did not load. I have obviously done something I should not have and so booked the car into Ford for diagnostic (£70.00), unfortunately (or perhaps fortunately) the earliest slot was April 11. It was time to trawl the internet to see if I could find a fix myself.
I downloaded Forscan (2 month free trial) version 2.3.51, and found a fault code B119F (GPS antenna open circuit) on the APIM module. There were no other faults. Roof mounted antenna issue seems quite common problem on various internet threads so I bought an antenna from Amazon, unplugged the OEM antenna and plugged in the new antenna (both antennas were Fakra female plugs) and mounted the new antenna under the roof with the supplied magnet. The fault on Forscan remained, the sat nav still wasn’t working there were no satellites on the Test Settings page. Time to trawl the internet again.
Various threads indicated the locked enabled GNSS and HIP sensor logging was the issue and upgrading to 3.4 would resolve the issue. The 3.4 update is not available for my vehicle on the Ford web site so I bit the bullet and used Cyanlabls Syn3 Updater.
After reading the documents and watching the video on the Syn3 home page I downloaded 3.4 Build 22110 and Maps F11 to usb using the Syn3 updater software on 07 March. This took some 2 hours. The usb was loaded into the car and downloaded successfully with out errors. I carried out a factory reset after removing the usb. I now have my sat nav back and I also have radio logos but no calm screen. The only minor issue I have found is that when the ignition is turned on the nav error appears, but disappears after about 10seconds and the maps are loaded, the radio logos also take the same time to load. I have checked the satellites on the Test Settings page and I have about 15 to 20, the Amazon antenna is still in use. I was very impressed and have cancelled my diagnostic appointment at the dealers.
Forscan however still shows the antenna fault B119F in the APIM, I cleared the fault but it comes straight back.
What really surprised me is that while my VIN is displayed on the about Sync screen and the Bezel Diagnostics APIM Part Numbers screen, the APIM Calibration in the Bezel Diagnostics is not for my VIN WF05XXXXXXXXX1752, but for VIN WF0AXXXXXXXXXX4717. For example my car is diesel with manual hand brake and ignition on off switch, the bezel diagnostics show gasoline, electric hand brake and key ignition. This second VIN does not show up in Forscan and my APIM settings are for my VIN.
How can I resolve this issue?
Old SYNC Version: 3.0.20204
New SYNC Version: 3.4.22110
Only error message is through Forscan, B119F
Syn3 Updater Version: 2.11.8.0 (Stable)
"C:\Users\johns\AppData\Local\CyanLabs\Syn3Updater\Logs\log-2023-03-07-17-44-28.txt"
Version: 3.0.20204
FileSystem: FAT32
VOICE=5U5T-14G391-AS_1644006548000.TAR.GZ
MAP=1U5T-14G421-BCJ_1644009116000.TAR.GZ
MAP=1U5T-14G421-BDJ_1644009729000.TAR.GZ
MAP=1U5T-14G421-BEJ_1644010041000.TAR.GZ
MAP=1U5T-14G421-BFJ_1644010644000.TAR.GZ
MAP=1U5T-14G421-BGJ_1644011311000.TAR.GZ
MAP=1U5T-14G421-BHJ_1644011371000.TAR.GZ
MAP=1U5T-14G421-BJJ_1644011473000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAG_1644245686000.TAR.GZ
VOICE_NAV=4U5T-14G422-BDG_1644012081000.TAR.GZ
VOICE_NAV=4U5T-14G422-BBG_1644011700000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCG_1644011850000.TAR.GZ
; CyanLabs Syn3Updater 2.11.8.0 Stable - reformat Mode - Sync 3.4.22110 EU
FILES (19)
5U5T-14G391-AS_1644006548000.TAR.GZ (1.5GB)
1U5T-14G421-BAJ_1644010894000.TAR.GZ (2.3GB)
1U5T-14G421-BBJ_1644008981000.TAR.GZ (478.9MB)
1U5T-14G421-BCJ_1644009116000.TAR.GZ (1.7GB)
1U5T-14G421-BDJ_1644009729000.TAR.GZ (1.1GB)
1U5T-14G421-BEJ_1644010041000.TAR.GZ (1.6GB)
1U5T-14G421-BFJ_1644010644000.TAR.GZ (2.4GB)
1U5T-14G421-BHJ_1644011371000.TAR.GZ (2.7GB)
1U5T-14G421-BJJ_1644011473000.TAR.GZ (24.1MB)
4U5T-14G422-BAG_1644245686000.TAR.GZ (2.3GB)
4U5T-14G422-BDG_1644012081000.TAR.GZ (2GB)
4U5T-14G422-BBG_1644011700000.TAR.GZ (2.1GB)
4U5T-14G422-BCG_1644011850000.TAR.GZ (1.6GB)
1U5T-14G424-BL_1646159765000.TAR.GZ (1.7KB)
[3/7/2023 3:38:44 PM] Selected Region: EU - Release: Sync 3.4.22110 - Map Version: F11 (2021) - EU (05 2022)
[3/7/2023 3:38:44 PM] Install Mode: Auto-Detect (reformat) Forced: False
[3/7/2023 3:38:44 PM] MY20 Protection: Auto-Detect
[3/7/2023 3:38:44 PM] Formatting USB drive
[3/7/2023 3:38:44 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[3/7/2023 3:38:53 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[3/7/2023 3:38:53 PM] Downloading: 1u5t-14g386-cb.tar.gz
[3/7/2023 3:38:56 PM] Validating: 1u5t-14g386-cb.tar.gz
[3/7/2023 3:38:56 PM] Downloaded: 1u5t-14g386-cb.tar.gz
[3/7/2023 3:38:56 PM] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[3/7/2023 3:38:56 PM] Downloading: 4U5T-14G423-AC_1615425645000.TAR.GZ
[3/7/2023 3:40:30 PM] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[3/7/2023 3:40:33 PM] Downloaded: 4U5T-14G423-AC_1615425645000.TAR.GZ
[3/7/2023 3:40:33 PM] Checking Existing File: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[3/7/2023 3:40:33 PM] Downloading: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[3/7/2023 3:42:31 PM] Validating: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[3/7/2023 3:42:35 PM] Downloaded: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[3/7/2023 3:42:35 PM] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[3/7/2023 3:42:35 PM] Downloading: 1U5T-14G658-AH_1644006443000.TAR.GZ
[3/7/2023 3:42:44 PM] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[3/7/2023 3:42:44 PM] Downloaded: 1U5T-14G658-AH_1644006443000.TAR.GZ
[3/7/2023 3:42:44 PM] Checking Existing File: 5U5T-14G391-AS_1644006548000.TAR.GZ
[3/7/2023 3:42:44 PM] Downloading: 5U5T-14G391-AS_1644006548000.TAR.GZ
[3/7/2023 3:46:16 PM] Validating: 5U5T-14G391-AS_1644006548000.TAR.GZ
[3/7/2023 3:46:22 PM] Downloaded: 5U5T-14G391-AS_1644006548000.TAR.GZ
[3/7/2023 3:46:22 PM] Checking Existing File: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[3/7/2023 3:46:22 PM] Downloading: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[3/7/2023 3:51:35 PM] Validating: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[3/7/2023 3:51:43 PM] Downloaded: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[3/7/2023 3:51:43 PM] Checking Existing File: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[3/7/2023 3:51:43 PM] Downloading: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[3/7/2023 3:52:48 PM] Validating: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[3/7/2023 3:52:50 PM] Downloaded: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[3/7/2023 3:52:50 PM] Checking Existing File: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[3/7/2023 3:52:50 PM] Downloading: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[3/7/2023 3:56:44 PM] Validating: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[3/7/2023 3:56:52 PM] Downloaded: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[3/7/2023 3:56:52 PM] Checking Existing File: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[3/7/2023 3:56:52 PM] Downloading: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[3/7/2023 3:59:22 PM] Validating: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[3/7/2023 3:59:26 PM] Downloaded: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[3/7/2023 3:59:26 PM] Checking Existing File: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[3/7/2023 3:59:26 PM] Downloading: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[3/7/2023 4:03:13 PM] Validating: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[3/7/2023 4:03:19 PM] Downloaded: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[3/7/2023 4:03:19 PM] Checking Existing File: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[3/7/2023 4:03:19 PM] Downloading: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[3/7/2023 4:08:57 PM] Validating: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[3/7/2023 4:09:06 PM] Downloaded: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[3/7/2023 4:09:06 PM] Checking Existing File: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[3/7/2023 4:09:06 PM] Downloading: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[3/7/2023 4:13:42 PM] Validating: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[3/7/2023 4:13:50 PM] Downloaded: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[3/7/2023 4:13:50 PM] Checking Existing File: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[3/7/2023 4:13:50 PM] Downloading: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[3/7/2023 4:20:02 PM] Validating: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[3/7/2023 4:20:12 PM] Downloaded: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[3/7/2023 4:20:12 PM] Checking Existing File: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[3/7/2023 4:20:12 PM] Downloading: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[3/7/2023 4:20:15 PM] Validating: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[3/7/2023 4:20:15 PM] Downloaded: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[3/7/2023 4:20:15 PM] Checking Existing File: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[3/7/2023 4:20:15 PM] Downloading: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[3/7/2023 4:25:29 PM] Validating: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[3/7/2023 4:25:38 PM] Downloaded: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[3/7/2023 4:25:38 PM] Checking Existing File: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[3/7/2023 4:25:38 PM] Downloading: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[3/7/2023 4:30:11 PM] Validating: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[3/7/2023 4:30:17 PM] Downloaded: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[3/7/2023 4:30:17 PM] Checking Existing File: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[3/7/2023 4:30:17 PM] Downloading: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[3/7/2023 4:35:16 PM] Validating: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[3/7/2023 4:35:23 PM] Downloaded: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[3/7/2023 4:35:23 PM] Checking Existing File: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[3/7/2023 4:35:23 PM] Downloading: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[3/7/2023 4:39:08 PM] Validating: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[3/7/2023 4:39:14 PM] Downloaded: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[3/7/2023 4:39:14 PM] Checking Existing File: 1U5T-14G424-BL_1646159765000.TAR.GZ
[3/7/2023 4:39:14 PM] Downloading: 1U5T-14G424-BL_1646159765000.TAR.GZ
[3/7/2023 4:39:14 PM] Validating: 1U5T-14G424-BL_1646159765000.TAR.GZ
[3/7/2023 4:39:14 PM] Downloaded: 1U5T-14G424-BL_1646159765000.TAR.GZ
[3/7/2023 4:39:15 PM] Preparing USB drive
[3/7/2023 4:39:15 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[3/7/2023 4:39:15 PM] Copying: 1u5t-14g386-cb.tar.gz
[3/7/2023 4:39:16 PM] Validating: 1u5t-14g386-cb.tar.gz
[3/7/2023 4:39:16 PM] Copied: 1u5t-14g386-cb.tar.gz
[3/7/2023 4:39:16 PM] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[3/7/2023 4:39:16 PM] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[3/7/2023 4:40:24 PM] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[3/7/2023 4:40:56 PM] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[3/7/2023 4:40:56 PM] Checking Existing File: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[3/7/2023 4:40:56 PM] Copying: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[3/7/2023 4:42:26 PM] Validating: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[3/7/2023 4:43:08 PM] Copied: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[3/7/2023 4:43:08 PM] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[3/7/2023 4:43:08 PM] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[3/7/2023 4:43:14 PM] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[3/7/2023 4:43:16 PM] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[3/7/2023 4:43:16 PM] Checking Existing File: 5U5T-14G391-AS_1644006548000.TAR.GZ
[3/7/2023 4:43:16 PM] Copying: 5U5T-14G391-AS_1644006548000.TAR.GZ
[3/7/2023 4:45:55 PM] Validating: 5U5T-14G391-AS_1644006548000.TAR.GZ
[3/7/2023 4:47:12 PM] Copied: 5U5T-14G391-AS_1644006548000.TAR.GZ
[3/7/2023 4:47:12 PM] Checking Existing File: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[3/7/2023 4:47:12 PM] Copying: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[3/7/2023 4:51:05 PM] Validating: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[3/7/2023 4:52:58 PM] Copied: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[3/7/2023 4:52:58 PM] Checking Existing File: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[3/7/2023 4:52:58 PM] Copying: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[3/7/2023 4:53:46 PM] Validating: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[3/7/2023 4:54:09 PM] Copied: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[3/7/2023 4:54:09 PM] Checking Existing File: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[3/7/2023 4:54:09 PM] Copying: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[3/7/2023 4:57:04 PM] Validating: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[3/7/2023 4:58:29 PM] Copied: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[3/7/2023 4:58:29 PM] Checking Existing File: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[3/7/2023 4:58:29 PM] Copying: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[3/7/2023 5:00:22 PM] Validating: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[3/7/2023 5:01:15 PM] Copied: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[3/7/2023 5:01:15 PM] Checking Existing File: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[3/7/2023 5:01:15 PM] Copying: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[3/7/2023 5:04:06 PM] Validating: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[3/7/2023 5:05:27 PM] Copied: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[3/7/2023 5:05:27 PM] Checking Existing File: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[3/7/2023 5:05:27 PM] Copying: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[3/7/2023 5:09:37 PM] Validating: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[3/7/2023 5:11:34 PM] Copied: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[3/7/2023 5:11:34 PM] Checking Existing File: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[3/7/2023 5:11:34 PM] Copying: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[3/7/2023 5:14:58 PM] Validating: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[3/7/2023 5:16:36 PM] Copied: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[3/7/2023 5:16:36 PM] Checking Existing File: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[3/7/2023 5:16:36 PM] Copying: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[3/7/2023 5:21:11 PM] Validating: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[3/7/2023 5:23:19 PM] Copied: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[3/7/2023 5:23:19 PM] Checking Existing File: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[3/7/2023 5:23:19 PM] Copying: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[3/7/2023 5:23:22 PM] Validating: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[3/7/2023 5:23:23 PM] Copied: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[3/7/2023 5:23:23 PM] Checking Existing File: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[3/7/2023 5:23:23 PM] Copying: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[3/7/2023 5:27:17 PM] Validating: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[3/7/2023 5:29:10 PM] Copied: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[3/7/2023 5:29:10 PM] Checking Existing File: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[3/7/2023 5:29:10 PM] Copying: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[3/7/2023 5:32:33 PM] Validating: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[3/7/2023 5:34:09 PM] Copied: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[3/7/2023 5:34:09 PM] Checking Existing File: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[3/7/2023 5:34:09 PM] Copying: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[3/7/2023 5:37:53 PM] Validating: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[3/7/2023 5:39:42 PM] Copied: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[3/7/2023 5:39:42 PM] Checking Existing File: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[3/7/2023 5:39:42 PM] Copying: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[3/7/2023 5:42:32 PM] Validating: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[3/7/2023 5:43:55 PM] Copied: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[3/7/2023 5:43:55 PM] Checking Existing File: 1U5T-14G424-BL_1646159765000.TAR.GZ
[3/7/2023 5:43:55 PM] Copying: 1U5T-14G424-BL_1646159765000.TAR.GZ
[3/7/2023 5:43:55 PM] Validating: 1U5T-14G424-BL_1646159765000.TAR.GZ
[3/7/2023 5:43:55 PM] Copied: 1U5T-14G424-BL_1646159765000.TAR.GZ
[3/7/2023 5:43:55 PM] Generating reformat.lst
[3/7/2023 5:43:55 PM] Generating autoinstall.lst
[3/7/2023 5:43:55 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
