Sync 3 Update Error
Current software 3.4.20351 Ford Explorer 2018. I wanted to update to the latest version of the F12 software and maps. I used the Cut Down Map Generator option (maps for Poland and PL voice). Syn3Updater automatically selected the downgrade options:
Unfortunately, an error appears:
Error in 4U5T-14G422-BAK_1682467228000.TAR.GZ
I don’t have a log
Old SYNC Version: 3.4.20351
I don't have a log
You can’t fit EU maps on a NA unit, SYN3 Updater literally warns you of this, you are using cut down maps but clearly not cut down enough
Thank you for your answer,
Can you help me and write what packages to use so that there is only a Polish map and Polish voice?
I used these in Cut Down Map Package Generator:
Have a look at this guide → Tutorial: Current EU Maps Installation on US Imported Vehicles , I’m sure you will find it helpful.
I do everything as in this tutorial.
My files are:
MAP_LICENSE=1U5T-14G424-BM_1683133039000.TAR.GZ
MAP=1U5T-14G421-BAK_1682464992000.TAR.GZ
MAP=1U5T-14G421-BBK_1682466740000.TAR.GZ
MAP=1U5T-14G421-BFK_1682467908000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCK_1682464838000.TAR.GZ
And error:
Is it a space problem?
Is there a description of these packages above somewhere so that I know which one is responsible for what?
Alternatively, what can I remove from the package to have a map of Poland and the PL language?
LOG:
Version: 3.4.20351
Install Mode: Auto-Wykrywanie (downgrade)
My20 Protection Enabled: Auto-Wykrywanie
Model: Wilk USB DISK 2.0 USB Device
FileSystem: FAT32
; CyanLabs Syn3Updater 2.12.2.0 Stable - downgrade Mode - Sync 3.4.23188 EU
FILES (13)
1u5t-14g386-cb.tar.gz (8,5MB)
1U5T-14G424-BM_1683133039000.TAR.GZ (1,7KB)
1U5T-14G421-BAK_1682464992000.TAR.GZ (2,3GB)
1U5T-14G421-BBK_1682466740000.TAR.GZ (541,8MB)
1U5T-14G421-BFK_1682467908000.TAR.GZ (2,5GB)
4U5T-14G422-BCK_1682464838000.TAR.GZ (1,7GB)
[29.09.2023 17:31:57] Selected Region: EU - Release: Sync 3.4.23188 - Map Version: EU - 2023-09-29 - 1696001454
[29.09.2023 17:31:57] Install Mode: Auto-Wykrywanie (downgrade) Forced: False
[29.09.2023 17:31:57] MY20 Protection: Auto-Wykrywanie
[29.09.2023 17:31:57] Formatting USB drive
[29.09.2023 17:31:57] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[29.09.2023 17:32:08] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.09.2023 17:32:08] Validate: 4U5T-14G381-AN_1552583626000.TAR.GZ (Failed!, Downloading)
[29.09.2023 17:32:08] Downloading: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.09.2023 17:34:30] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.09.2023 17:34:32] Downloaded: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.09.2023 17:34:32] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[29.09.2023 17:34:32] Downloading: GB5T-14G386-SC_85041.tar.gz
[29.09.2023 17:34:33] Validating: GB5T-14G386-SC_85041.tar.gz
[29.09.2023 17:34:33] Downloaded: GB5T-14G386-SC_85041.tar.gz
[29.09.2023 17:34:33] Checking Existing File: 1u5t-14g386-cb.tar.gz
[29.09.2023 17:34:33] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[29.09.2023 17:34:33] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[29.09.2023 17:34:33] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[29.09.2023 17:34:33] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[29.09.2023 17:34:42] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[29.09.2023 17:34:42] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[29.09.2023 17:34:46] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[29.09.2023 17:34:46] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[29.09.2023 17:34:46] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[29.09.2023 17:34:46] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[29.09.2023 17:34:52] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[29.09.2023 17:34:52] Checking Existing File: 1U5T-14G424-BM_1683133039000.TAR.GZ
[29.09.2023 17:34:52] Validated: 1U5T-14G424-BM_1683133039000.TAR.GZ (Skipping Download)
[29.09.2023 17:34:52] Checking Existing File: 1U5T-14G421-BAK_1682464992000.TAR.GZ
[29.09.2023 17:35:08] Validated: 1U5T-14G421-BAK_1682464992000.TAR.GZ (Skipping Download)
[29.09.2023 17:35:08] Checking Existing File: 1U5T-14G421-BBK_1682466740000.TAR.GZ
[29.09.2023 17:35:12] Validated: 1U5T-14G421-BBK_1682466740000.TAR.GZ (Skipping Download)
[29.09.2023 17:35:12] Checking Existing File: 1U5T-14G421-BFK_1682467908000.TAR.GZ
[29.09.2023 17:35:30] Validated: 1U5T-14G421-BFK_1682467908000.TAR.GZ (Skipping Download)
[29.09.2023 17:35:30] Checking Existing File: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[29.09.2023 17:35:40] Validated: 4U5T-14G422-BCK_1682464838000.TAR.GZ (Skipping Download)
[29.09.2023 17:35:40] Preparing USB drive
[29.09.2023 17:35:40] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.09.2023 17:35:40] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.09.2023 17:37:00] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.09.2023 17:37:18] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.09.2023 17:37:18] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[29.09.2023 17:37:18] Copying: GB5T-14G386-SC_85041.tar.gz
[29.09.2023 17:37:19] Validating: GB5T-14G386-SC_85041.tar.gz
[29.09.2023 17:37:19] Copied: GB5T-14G386-SC_85041.tar.gz
[29.09.2023 17:37:19] Checking Existing File: 1u5t-14g386-cb.tar.gz
[29.09.2023 17:37:19] Copying: 1u5t-14g386-cb.tar.gz
[29.09.2023 17:37:22] Validating: 1u5t-14g386-cb.tar.gz
[29.09.2023 17:37:22] Copied: 1u5t-14g386-cb.tar.gz
[29.09.2023 17:37:22] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[29.09.2023 17:37:22] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[29.09.2023 17:37:22] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[29.09.2023 17:37:22] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[29.09.2023 17:37:22] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[29.09.2023 17:37:22] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[29.09.2023 17:42:48] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[29.09.2023 17:43:37] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[29.09.2023 17:43:37] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[29.09.2023 17:43:37] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[29.09.2023 17:45:59] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[29.09.2023 17:46:19] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[29.09.2023 17:46:19] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[29.09.2023 17:46:19] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[29.09.2023 17:46:31] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[29.09.2023 17:46:32] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[29.09.2023 17:46:32] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[29.09.2023 17:46:32] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[29.09.2023 17:49:32] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[29.09.2023 17:49:58] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[29.09.2023 17:49:58] Checking Existing File: 1U5T-14G424-BM_1683133039000.TAR.GZ
[29.09.2023 17:49:58] Copying: 1U5T-14G424-BM_1683133039000.TAR.GZ
[29.09.2023 17:49:58] Validating: 1U5T-14G424-BM_1683133039000.TAR.GZ
[29.09.2023 17:49:58] Copied: 1U5T-14G424-BM_1683133039000.TAR.GZ
[29.09.2023 17:49:58] Checking Existing File: 1U5T-14G421-BAK_1682464992000.TAR.GZ
[29.09.2023 17:49:58] Copying: 1U5T-14G421-BAK_1682464992000.TAR.GZ
[29.09.2023 17:58:11] Validating: 1U5T-14G421-BAK_1682464992000.TAR.GZ
[29.09.2023 17:59:20] Copied: 1U5T-14G421-BAK_1682464992000.TAR.GZ
[29.09.2023 17:59:20] Checking Existing File: 1U5T-14G421-BBK_1682466740000.TAR.GZ
[29.09.2023 17:59:20] Copying: 1U5T-14G421-BBK_1682466740000.TAR.GZ
[29.09.2023 18:01:11] Validating: 1U5T-14G421-BBK_1682466740000.TAR.GZ
[29.09.2023 18:01:13] Copied: 1U5T-14G421-BBK_1682466740000.TAR.GZ
[29.09.2023 18:01:13] Checking Existing File: 1U5T-14G421-BFK_1682467908000.TAR.GZ
[29.09.2023 18:01:13] Copying: 1U5T-14G421-BFK_1682467908000.TAR.GZ
[29.09.2023 18:10:03] Validating: 1U5T-14G421-BFK_1682467908000.TAR.GZ
[29.09.2023 18:11:13] Copied: 1U5T-14G421-BFK_1682467908000.TAR.GZ
[29.09.2023 18:11:13] Checking Existing File: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[29.09.2023 18:11:13] Copying: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[29.09.2023 18:17:11] Validating: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[29.09.2023 18:18:02] Copied: 4U5T-14G422-BCK_1682464838000.TAR.GZ
[29.09.2023 18:18:02] Generating reformat.lst
[29.09.2023 18:18:02] Generating autoinstall.lst
[29.09.2023 18:18:02] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Are you sure your unit has nav?
To recover the unit, do not install any nav package.
Once the unit is operational, create and run an interrogator log, post the output once you have it so that we can review it (redact the vin in you care about it).
Also, the USB you are using seems generic and cheap, you should use a quality branded one.
Thank you very much for your help. It turned out that two flash drives were bad. On the third it went without problems :+1:
