Sync 3 update to 3.4
Hi, During the installation of the update, the ‘extracting map package’ process is taking a very long time it’s been over an hour. Do you have a solution for this, or is it supposed to take this long?
Old SYNC Version: 3.0.20204
Syn3 Updater Version: 2.13.1.0
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2025-02-18" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>WF0EXXWPCEHU27737</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>JR3T-14G381-AX</d2p1:Response>
</d2p1:DID>
<d2p1:Response>4a5233542d3134473339312d4145000000000000000000004a5233542d3134473432312d4243000000000000000000004a5233542d3134473432342d4243000000000000000000004a5233542d3134473432332d4142000000000000000000004a5233542d3134473432322d424300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>d604a81e</d2p1:Response>
</d2p1:DID>
<d2p1:Response>6a1be931</d2p1:Response>
</d2p1:DID>
<d2p1:Response>086a059a1002fe0206c2</d2p1:Response>
</d2p1:DID>
<d2p1:Response>504c0106c00a488000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0203000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01001d00240102</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1ac21aa42bd0</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>07003300000000171c000056566d006a</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-GB5T-14G371-CB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HB5T-14G380-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HB5T-14G371-FCA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G375-FA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>LW2200XS</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>GB5T-14G374-CB</d2p1:Response>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response>60:64:05:37:da:7b</d2p1:Response>
</d2p1:DID>
<d2p1:Response>60:64:05:37:da:7c</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2025-02-18T12:16:29+00:00" RAM="1041371136" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/usb0/" total="58G" available="58G"/>
<d2p1:PartitionHealth type="/fs/tmpfs/" total="128M" available="127M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="3.2M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="18G" available="129M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="16G" available="867M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.9G" available="7.6M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="1.0G" available="6.1M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1024M" available="682M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1024M" available="40M"/>
<d2p1:PartitionHealth type="/fs/images/" total="55G" available="15G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Sounds about right. The NA version takes almost an hour and it is much smaller. I have heard stories of it taking 2 hours for the EU version.
Is it even possible to exit this update mode and start the radio normally?
Nope you just have to grin and bear it.
This is nothing I had a WiFi update take a week to complete. Atleast I could use the Radio while it updated though.
you are using a bad and slow USB, EU should take 48minutes if you are not be limited by your USB read speed.
Mondeo has 3.0 usb? I bought yesterday samsung pendrive
no but a slow usb 3.0 drive generally has a much faster chip so even on a usb2.0 port a usb3.0 usb will be faster than most usb 2.0 drives.
I found information on this forum, that it can be 4h of instalation? Is that true?
Guys, what should i do, please help, i have no idea what is going wrong, now instalation is from ssd to usb
Provide this, as requested:
Try the other USB port with nothing plugged in the other port.
Could be a worn port.
Using an external SSD drive or a SD/mSD usb adapter is not a good idea.
When i try to plug to other usb port nothing happend, probably the usb hub is broken. I order the new one and we will see
I managed to fix it, the problem was the USB hub. I quickly bought an adapter from mini USB to USB-A, and it worked on the first try. Thank you, guys, for your help!
