Sync 3 Upgrade
I recently upgraded my 2017 mustang pp1 to sync 3. Everything worked perfectly in had to do the start button fix where you bypass the harness. BUT my radio works just fine but when I use android auto or bluetooth the driver door speaker doesn’t do anything. Any help would be appreciated
Install Type: OEM Replacement
Old SYNC Version: 2.2.1680
Only possible thing could be the acm error but that’s fkr the antenna. I’m not sure what to do.
Syn3 Updater Version: Not sure
Phone
All of the sound comes from the ACM. Your APIM takes the Bluetooth data and moves it to the ACM. I would bet you have bad ACM AB settings.
I just put my old acm back in and its working perfectly fine.
The ACM AB has to match what’s in the APIM AB.
Odds are the config of the new APIM is quite right.
