Sync 3 usb hub not working
Hey I was wondering if anyone has or had the issue I got. I updated from a sync 2 to a 3. I’m pretty sure the apim is a 1 gen because it comes with 2 usb port on the back. But I bought a carplay module hub and it says the usb is not regonized it turns on but it wont work I did connect a cable on the other usb port and that port does charges but wont read a usb so I can update it.
Old SYNC Version: 2.2.16280
New SYNC Version: 2.2.16280
sometimes a message would appear saying that it doesn’t recognized usb
Care to inform which version the unit is running?
Does Android Auto work?
Are you referencing the “hub not supported” message?
Does the USB work for median playback from a pendrive?
Did you buy a cheap Chinese hub that are all over the internet?
Hey! I bought the hub at a ford dealer
What’s the model number on that hub?
Im using this one
HC3Z-19A387-F (BLUE BACKLIGHTING) Ford (Wide 2 USB-A Port)
Should work fine.
Did you buy an adapter for the power to the hub?
USB is the black connector on the APIM, the gray connector is not used.
yes, I bought 2 different one. But it turns kinda blue around the port
Then you have power to the hub if the light turns blue.
If you have not updated to Sync 3.0.20204 or Sync 3.2+ then the hub will not work. What version is installed?
2.2.16280 it should this one here. I cant update it because it dosent read/connect to the stuff I plug in to the hub
Put the old hub back in, do the upgrade, then replace the hub.
Use the automated method.
It is possible that the Sync 3 unit has an issue with the USB port bad.
Would the sync 2 hub work?
Not sure if the Sync 2 hub will work on Sync 3. Never tried it.
Did you try both USB ports on the hub?
well I can try, because I got another hub but it is the same it wont work
Yes, the other port on the back of the apim does work in terms that it charges
Found out the problem, it was the car usb cable
That’ll do it.
Also by any chance do any of you know if this is a nav or non nav apim?
Run an interrogator log against it to find out
