SYNC 3 V3.4.23188 Red screen issue
after updating the screen from3.0 build 18093 to 3.4 Build 22020 then to v3.4.23188 gave me a red screen with the below error :
Error in 4u5t-14G23-FC-1615431949000.TAR.GC
so please i need your support in fixing this issue
SYNC Region: ROW
Install Type: Unknown
Old SYNC Version: 3.0
Syn3 Updater Version: v3.4.23188
not available
It seems you are trying to install maps on a non-NAV APIM.
If so, recreate the USB without maps.
Error update packages not found … :disappointed:
Is the upgrade USB the only device connected?.
yes … log :point_down:
Version: 3.4.22020
Region: ROW
Model: JetFlash Transcend 8GB USB Device
; CyanLabs Syn3Updater 2.12.5.0 Stable - Autoinstall Mode - Sync 3.4.23188 ROW
Item2 = VOICE - 5U5T-14G391-BS_1660772122000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-BS_1660772122000.TAR.GZ
Item3 = ENH_DAB - 1U5T-14G658-AH_1644006443000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G658-AH_1644006443000.TAR.GZ
FILES (4)
5U5T-14G391-BS_1660772122000.TAR.GZ (1.4GB)
[2/17/2024 5:33:27 PM] Selected Region: ROW - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[2/17/2024 5:33:27 PM] Install Mode: Auto-Detect (autoinstall) Forced: False
[2/17/2024 5:33:27 PM] MY20 Protection: Auto-Detect
[2/17/2024 5:33:27 PM] Formatting USB drive
[2/17/2024 5:33:27 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2/17/2024 5:33:37 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/17/2024 5:33:37 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[2/17/2024 5:33:37 PM] Checking Existing File: 5U5T-14G391-BS_1660772122000.TAR.GZ
[2/17/2024 5:33:37 PM] Downloading: 5U5T-14G391-BS_1660772122000.TAR.GZ
[2/17/2024 5:43:02 PM] Validating: 5U5T-14G391-BS_1660772122000.TAR.GZ
[2/17/2024 5:43:14 PM] Downloaded: 5U5T-14G391-BS_1660772122000.TAR.GZ
[2/17/2024 5:43:14 PM] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[2/17/2024 5:43:15 PM] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[2/17/2024 5:43:15 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/17/2024 5:43:27 PM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[2/17/2024 5:43:27 PM] Preparing USB drive
[2/17/2024 5:43:27 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/17/2024 5:43:27 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/17/2024 5:43:27 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/17/2024 5:43:27 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/17/2024 5:43:27 PM] Checking Existing File: 5U5T-14G391-BS_1660772122000.TAR.GZ
[2/17/2024 5:43:27 PM] Copying: 5U5T-14G391-BS_1660772122000.TAR.GZ
[2/17/2024 5:50:00 PM] Validating: 5U5T-14G391-BS_1660772122000.TAR.GZ
[2/17/2024 5:51:46 PM] Copied: 5U5T-14G391-BS_1660772122000.TAR.GZ
[2/17/2024 5:51:46 PM] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[2/17/2024 5:51:46 PM] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[2/17/2024 5:52:02 PM] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[2/17/2024 5:52:06 PM] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[2/17/2024 5:52:06 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/17/2024 5:52:06 PM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/17/2024 5:55:57 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/17/2024 5:56:59 PM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/17/2024 5:56:59 PM] Generating Autoinstall.lst
[2/17/2024 5:57:00 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
This is wrong, you are not on 3.4.
Select any 3.0 as current and redo everything.
please let me know the steps on how to downgrade to the old version ?
As clearly stated, you can’t downgrade back to 3.0.
It is a little unclear…were you actually able to update to version 3.4.22020 successfully and everything worked fine before attempting to update to version 3.4.23188?
As mentioned you cannot downgrade to 3.0.20204 or whatever but you can use that as your current version to update to 3.4.23188 if you are still on version 3.0.
