SYNC 4 Retrofit in Ford Fiesta ST MK8
Here is a video showing my Fiesta ST MK8 2019 with a Retrofitted SYNC 4 APIM (Not Sync 3.4) and a Digital Dash / IPC
Most functions work, AA Wireless, BT, DAB, FM, AM, Settings, B&O, Reverse Camera, Parking Sensors etc.
APIM is Non Nav as unable to source a EU APIM and can’t easily convert the region like we can with SYNC 3, there for no GPS Antenna connection and therefore GPS and Compass don’t work.
TCU connectivity is broken, this is a WIP but unlikely to be fixed
DAB Radio “Stations” button doesn’t display any stations, skipping back/forward works fine though
WiFi is not working as previously paired to another device and no known reset method is known by the public.
Error in my BCM and RCM for unable to communicate with APIM
Error in my APIM for Incompatible Configuration and unsupported screen
Error in my IPC for missing bus used for Boost Gauge, OIL etc (due to digital dash)
All in all, i think the Wireless AA and imo better sound quality are enough to justify the small amount i paid for this APIM.
UCDS Config
WorkingSYNC4ApimFiestaMk8-231221.xml (1.3 KB)
AsBuilt Conversion
7D0-01-01 8749 0260 808B
7D0-01-02 0000 D800 10C2
7D0-01-03 0000 0000 00DB
7D0-01-04 0000 0000 00DC
7D0-02-01 45A0 1ECA 00A7
7D0-02-02 0000 00C4 009F
7D0-02-03 A040 0000 00BC
7D0-03-01 554B 0B0A 0090
7D0-03-02 0000 0701 01E5
7D0-03-03 0000 0000 00DD
7D0-04-01 0500 0000 00E1
7D0-05-01 018A 2800 0090
7D0-05-02 0000 0000 00DE
7D0-05-03 0000 0000 00DF
7D0-06-01 1908 1908 2646
7D0-06-02 5332
7D0-07-01 0B05 3300 0022
7D0-07-02 0000 6428 006C
7D0-07-03 0056 565F 00EC
7D0-07-04 6143
7D0-08-01 C600 0001 00A7
7D0-08-02 0000 0000 00E1
7D0-09-01 0000 0000 00E1
7D0-09-02 0000 0000 00E2
7D0-09-03 0000 0000 00E3
7D0-09-04 1000 0000 00F4
7D0-09-05 0000 0000 00E5
7D0-10-01 0000 0000 00E8
7D0-10-02 0000 0000 00E9
7D0-10-03 0000 0000 00EA
7D0-10-04 0000 0000 00EB
7D0-10-05 0000 0000 00EC
HI, How did you manage to make UCDSYS see APIM in vehicle? I’ve tried with mine and nothing but works on bench .
Thanks
you just select a car with a SYNC 4 APIM and then select the SYNC 4 APIM, you don’t need to “make UCDS see your APIM”
I have Genuine UCDSYS cable and Software latest update. I disconnect HS CAN and tried ticking use MM cAN too but failed to read. Strange as I had a Mach e new module. Failed every time. Plugged it into bench TDK unit and it reads and writes no problem.I plugged it into transit connect facelift but should still have read. Did you remove HS can ? Or does it now read through it or Gateway module routes to HS3?
Would you happen to know what line controls the car connectivity settings in the APIM with forscan?
I have a sync 4 retrofit in my Maverick and everything works except wireless AA/CarPlay. If I go into the connectivity settings the wireless app projection won’t switch from off to on. I was looking at line 7D0-02-02 xxxx xx*x xx–
But it doesn’t see to make a difference
You need to have your APIM WIFI working on Sync 4 for the wireless CP/AA to enable. Check that it is enabled and working. This may require turning on automatic updates.
The connectivity settings for Sync 4 are 7D0-02-02: xxxx-xx*x-xx–, but this does not affect the APIM WIFI, it is for the FordPass application.
Also, if you did not add the 2021+ TCU, you will need to set 7D0-02-02: xxxx-xxx*-xx-- to not get GPS from the TCU. This does not affect the WIFI, but will affect your maps application using CP/AA, as those apps use the vehicle GPS for NAV.
Ok thanks for the info and all the help I really appreciate it. I got 99% of this working. I have one last question. What feeds the satelite radio now playing data to the instrument cluster, the apim or acm? FM and AM will show on the cluster but satellite radio just said audio off. I went through the APIM and ACM database and dont see something that stands out on what controls that.
It is the IPC.
720-05-01 *xxx xxxx xxxx
Entertainment Non-Sync Source - ENSS AM/FM (ENSSAMFM), ENSS CD (ENSSCD), ENSS DAB (ENSSDAB), ENSS Sirius (ENSSS)
0=ENSSAMFM Disabled, ENSSCD Disabled, ENSSDAB Disabled, ENSSS Disabled
1=ENSSAMFM Disabled, ENSSCD Disabled, ENSSDAB Disabled, ENSSS Enabled
2=ENSSAMFM Disabled, ENSSCD Disabled, ENSSDAB Enabled, ENSSS Disabled
3=ENSSAMFM Disabled, ENSSCD Disabled, ENSSDAB Enabled, ENSSS Enabled
4=ENSSAMFM Disabled, ENSSCD Enabled, ENSSDAB Disabled, ENSSS Disabled
5=ENSSAMFM Disabled, ENSSCD Enabled, ENSSDAB Disabled, ENSSS Enabled
6=ENSSAMFM Disabled, ENSSCD Enabled, ENSSDAB Enabled, ENSSS Disabled
7=ENSSAMFM Disabled, ENSSCD Enabled, ENSSDAB Enabled, ENSSS Enabled
8=ENSSAMFM Enabled, ENSSCD Disabled, ENSSDAB Disabled, ENSSS Disabled
9=ENSSAMFM Enabled, ENSSCD Disabled, ENSSDAB Disabled, ENSSS Enabled
A=ENSSAMFM Enabled, ENSSCD Disabled, ENSSDAB Enabled, ENSSS Disabled
B=ENSSAMFM Enabled, ENSSCD Disabled, ENSSDAB Enabled, ENSSS Enabled
C=ENSSAMFM Enabled, ENSSCD Enabled, ENSSDAB Disabled, ENSSS Disabled
D=ENSSAMFM Enabled, ENSSCD Enabled, ENSSDAB Disabled, ENSSS Enabled
E=ENSSAMFM Enabled, ENSSCD Enabled, ENSSDAB Enabled, ENSSS Disabled
F=ENSSAMFM Enabled, ENSSCD Enabled, ENSSDAB Enabled, ENSSS Enabled
Ok awesome. I wasnt sure if this was something on the IPC that needed to be enabled or if it was part of the APIM AB.
Thanks again, you’ve been a huge help
Also, if you have HD Radio (HDR), look at the line above that to enable the metadata for it in the IPC.
