Sync Color Theme (2020 Lincoln Nautilus)
You would just need an adapter to connect to the car via ODB (this is recommended) and use FORScan to modify the startup animations and theme.
I have adapter and forscan but cant get lincoln grey theme on my car and grey navigation bar. Mine is blue
This forum post here might help. Try to change the values to the Lincoln ones.
See the APIM Database in this site: https://cyanlabs.net/ford-apim-asbuilt-db/
7D0-03-01 xxxx XXxx xxxx:
Visual Themes Sync Versions 3.0 thru 3.3
00=Ford Classic (Blue Theme, Multi-colored Buttons)
01=Ford Timeless (Blue Theme, Blue Buttons)
02=Lincoln Timeless (Gold Theme, Black Icons)
03=Lincoln Next (Gold Theme, White Icons)
04=Ford GT (All Blue Theme for 2017 Ford GT)
Visual Themes Sync Version 3.4 (In addition to above)
05=8" Landscape (Horizontal) (Sync 3.4)
06=8" Portrait (Vertical) (Sync 3.4)
07=10" Landscape (Horizontal) (Sync 3.4)
08=10" Portrait (Vertical) (Sync 3.4)
For 3.4 only: These are the only base themes in 3.4, as all others are now derivatives of these 2 themes. There are 3 variations of each.
00=Ford MY20
03=Lincoln MY20
Ford Theme (Master Enable): must also set 7D0-01-02 0xxx xxxx xxxx for Ford themes above.
Lincoln Theme (Master Enable): must also set 7D0-01-02 8xxx xxxx xxxx for Lincoln themes above.
Ford GT - Removed from build 3.0.19149 and above.
7D0-02-01 xxxx XXxx xxxx:
Boot Screen Animations Sync Versions 3.0 thru 3.3
00=Ford/Lincoln (Default under 3.4)
01=Ford/Lincoln (Default under 3.0 thru 3.3)
02=xx
03=Lincoln Black Label - must also set 7D0-01-02 8xxx xxxx xxxx
04=Lincoln Presidential - must also set 7D0-01-02 8xxx xxxx xxxx
05=Raptor Ford Performance
06=Mustang Ford Performance
07=Shelby GT350 (Formerly Ford-GT - Removed from build 3.0.19149 and above.)
08=Vignale
09=Shelby Mustang R1
0A=Ford (Change if you want Ford Boot Splash with Lincoln Theme)
0B=ST Ford Performance
0C=RS Ford Performance
0D=GT Ford Performance
0E=Lincoln Continental - must also set 7D0-01-02 8xxx xxxx xxxx
0F=Lincoln Navigator - must also set 7D0-01-02 8xxx xxxx xxxx
Boot Screen Animations Sync Version 3.4 (In addition to above)
10=EVO Ford Performance
11=Aviator - must also set 7D0-01-02 8xxx xxxx xxxx
12=Explorer
13=Corsair - must also set 7D0-01-02 8xxx xxxx xxxx
14=Nautilus - must also set 7D0-01-02 8xxx xxxx xxxx
15=xx
16=xx
17=Bronco
Hey Guys, you can change the theme easily with Forscan. The problem is you can change the startup logo that displays on startup, but on shutdown it displays the wrong logo.
For instance I’m using the Ford logo with the Lincoln Black theme. So when the system boots it shows the Ford logo as normal but on shutdown it shows the Lincoln logo.
You can change the boot screen, but the ending logo is built into the theme.
