My car is a 2015 C-Max energi SEL with nav. I recently put in a screen and apim from a 2018 fusion energy SE with no nav to upgrade to sync 3 (version 2.3) My question is should I upload the as-built apim file from my 2015 or should I use a donor 2017 Vin with matching trim and no nav. Or is there another solution I am not thinking of? Thanks, newbie here.
Old SYNC Version: 3.8
New SYNC Version: 2.3
You cannot use the AB from a non-Sync3 APIM on a Sync3 APIM.
You should be using a first year (your model, first year Sync3 was offered on it) donor VIN AB that’s close to your trim/option level
Thanks, very much appreciated. I found a 2016 Energi vin that is working well so far.
Don
Fusion didn’t come with Sync3 until 2017, its a different logic than the CMax.
CMax is closer to an Escape or Focus.
2016 CMax with Sync3 & NAV Check car by VIN & get the vehicle history | CARFAX
Download the AB from https://www.motorcraftservice.com/Asbuilt/
Use Forscan to turn off the NAV.
