I’ve created an interrogator log into an USB drive but the XML generate will cause an error when read with Syn3 Updater.
The only information that I get out of it is the following:
VIN: (REMOVED)
Version JR3T-14G381-AX
APIM Model: HB5T-14G371-FFB
I’ve recently installed version 3.0.20204 upgrading from 2.3.17109 on a Ford Kuga 2018 model. Now I wanted to understand if I can upgrade to the latest Sync version (3.4.x) but I’m not sure if this is allowed for my APIM model?
Is there a way to find out about this?
Thanks,
Old SYNC Version: 2.3.17109
New SYNC Version: 3.0.20204
The interrogator log cannot be read.
Our records show that APIM model HB5T-14G371-FFB is a 32GB NAV APIM, so no issues about storage there.
Also, that APIM should not be MY20, so you should be fine.
I’m using “should” since I’m saying this based on the APIM’s model , which is an H series APIM that should not be MY20.
The same applied to the J series, until Ford started pushing out J series APIMs with MY20 components…
We have not seen any issues with H series so far , so if your unit was never serviced then it’s ok.
So with the assumption that MY20 is not there do you think I can try to update to the latest version?
Will the upgrade process be able to auto determine if it can continue before reformatting the device etc?
Yes, assuming your unit is not MY20, it’s safe to proceeded.
No, the process won’t validate anything and will try to upgrade the system.
On a side note, Syn3Updater’s validation is based on the APIM model. It cannot read the manufacturer date.
Based on the H series APIM, it would flag the APIM as not-MY20, as I did.
You are not following me…
It does not matter, the information you provided (APIM model) is the information Syn3Updater would use for flagging a MY20 model, and in your case, would not flag it as MY20.
So if you were to use a different interrogator log version to produce a valid log, Syn3Updater would say it’s not MY20.
If you want to be 100% sure, you need to gain physical access to the unit and check the APIM and screen manufacture date.
