Hi
I’m new on this forum.
I try to find solution for my issues but I didn’t find anything.
A want update my sync3 to latest version on My Ford Fusion Energi 2017 (PHEV) APIM version HP5T-14G371-CAF (32GB navi)
I use interrogator GB5T-14G386-AC and based on log file sync3 updater show current version as 3.4.22021 but sync3 information screen show Software version 3.4 compilation 20021 product.
Apim was adopted to eu by somone when car was imported to eu, and I heve no idea what version was originally and what methods he use, I also haven’t contact with him to ask.
I have couple another issues with it.
Harmonogram is hard to program, and it clear and switched off by self after couple days.
Sometimes charging times is revert by self to setings from first settings I make.
Tcu modem serial no. don’t show.
What should I do to update and fix problem’s
Inerrogator log:
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2025-01-26” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>3FA6P0PU5HRXXXXXX</p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNCGEN3</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue=“c1840008”/>
<d2p1:DTC DTCValue=“c1980008”/>
</p:BroadcastDTCType>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:Response5U5T-14G381-EB</d2p1:Response>
</d2p1:DID>
d2p1:Response315535542d3134473432312d424146000000000000000000315535542d3134473432312d424246000000000000000000315535542d3134473432312d424646000000000000000000315535542d3134473432342d424800000000000000000000355535542d3134473339312d414b00000000000000000000345535542d3134473432322d424345000000000000000000345535542d3134473432332d414100000000000000000000315535542d3134473635382d414500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Response756671fe</d2p1:Response>
</d2p1:DID>
d2p1:Response3f92a261</d2p1:Response>
</d2p1:DID>
d2p1:Response2a2a050210028902868a</d2p1:Response>
</d2p1:DID>
d2p1:Response504c0101c002409000000005</d2p1:Response>
</d2p1:DID>
d2p1:Response0003000000</d2p1:Response>
</d2p1:DID>
d2p1:Response01000200030001</d2p1:Response>
</d2p1:DID>
d2p1:Response1ac21aa42bd0</d2p1:Response>
</d2p1:DID>
d2p1:Response80</d2p1:Response>
</d2p1:DID>
d2p1:Response07003300000000171c000056566d006a</d2p1:Response>
</d2p1:DID>
d2p1:ResponseDS-GB5T-14G371-CB</d2p1:Response>
</d2p1:DID>
d2p1:ResponseHP5T-14G380-BA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseHP5T-14G371-CAF</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseVV4MVFPA</d2p1:Response>
</d2p1:DID>
d2p1:Response00</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:ResponseGB5T-14G374-CB</d2p1:Response>
</d2p1:DID>
d2p1:Response/
</d2p1:DID>
d2p1:Response88:c2:55:7c:c9:6c</d2p1:Response>
</d2p1:DID>
d2p1:Response88:c2:55:7c:c9:6d</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2025-01-26T14:13:29+00:00” RAM=“1080291328” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.1G” available=“676K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.2G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.6G” available=“29M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“3.4G” available=“33M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.9G” available=“8.5M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/grace” total=“1.0G” available=“59M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“877M”/>
<d2p1:PartitionHealth type=“/fs/mp/” total=“1.4G” available=“143M”/>
<d2p1:PartitionHealth type=“/fs/mp/resources” total=“74M” available=“380K”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“25G” available=“9.5G”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Old SYNC Version: 3.0
No errors
