Sync3 Update Failed
I tried to update Sync3 version from 3.4.21265 to 3.4.23188.
Newly installed Sync3 (3.4.21265) showed GPS problem. So, I decided to update Sync3 to latest version.
Before I update, Interrogator Logs shows Old Sync3 installed 2 Packages (4U5T-14G391-EJ, 4U5T-14G423-EA).
Version 5U5T-14G381-EU
APIM Model: JS7T-14G371-JED
APIM Type: Non-Navigation
APIM Size: 8GB
APIM Free Space: 1.8G
2024-06-02 ์˜คํ›„ 7:44:26 +00:00
Partition Type = Free / Total
/fs/Nuance/ = 23M / 265M
/fs/Nuance/grace = 41M / 793M
/fs/rwdata/ = 962M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 132M / 1.4G
/fs/images/ = 1.8G / 3.0G
Installed Packages
4U5T-14G391-EJ
4U5T-14G423-EA
I justed selected packages VOICE and APPS without GRACENOTES.
I tried to install but MEM_ERR03 reported.
How can I update Sync3 ?
(I buyed Sync3 from Aliexpress)
Or, How can I calibrate GPS coordination correctly ?
(Iโ€™ve already tried DR calib and master reset)
SYNC Region: CN
Install Type: Replica
Old SYNC Version: 3.4.21265
MEM_ERR03
Syn3 Updater Version: 2.12.5
Operating System: Microsoft Windows 10 Enterprise (1709)
Version: 3.4.21265
Region: CN
Model: USB Device
; CyanLabs Syn3Updater 2.12.5.0 Stable - Autoinstall Mode - Sync 3.4.23188 NA
Item3 = APPS - NU5T-14G381-AD_1689364279000.TAR.GZ
Open3 = SyncMyRide\NU5T-14G381-AD_1689364279000.TAR.GZ
FILES (3)
[2024-06-02 ์˜คํ›„ 7:53:04] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[2024-06-02 ์˜คํ›„ 7:53:04] Install Mode: Auto-Detect (autoinstall) Forced: False
[2024-06-02 ์˜คํ›„ 7:53:04] MY20 Protection: Disabled / Not MY20
[2024-06-02 ์˜คํ›„ 7:53:04] Formatting USB drive
[2024-06-02 ์˜คํ›„ 7:53:04] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2024-06-02 ์˜คํ›„ 7:53:13] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:53:13] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[2024-06-02 ์˜คํ›„ 7:53:13] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:53:15] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[2024-06-02 ์˜คํ›„ 7:53:15] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:53:17] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[2024-06-02 ์˜คํ›„ 7:53:17] Preparing USB drive
[2024-06-02 ์˜คํ›„ 7:53:17] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:53:17] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:53:17] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:53:17] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:53:17] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:53:17] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:54:46] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:54:47] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:54:47] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:54:47] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:58:11] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:58:13] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-06-02 ์˜คํ›„ 7:58:13] Generating Autoinstall.lst
[2024-06-02 ์˜คํ›„ 7:58:13] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Do you have any pictures of the APIM?
You only have 8G of space and all the cache is full. Iโ€™m not sure you should have chinese characters in the log you posted.
Your unit is NO-NAV, only 8GB, so forget about NAV (Iโ€™m not sure why itโ€™s telling you NAV FAILURE). Other than that, follow this guide โ†’ Tutorial: Sync 3.4 NON-NAV APIM: Failure to Update to Newer Version Sync 3.4
Thatโ€™s ok, logs always may contain some locale characters since itโ€™s created by Syn3updaterโ€ฆ
Itโ€™s AM/PM in the users locale
Afternoon (์˜คํ›„)
Iโ€™m thinking heโ€™s getting a GPS fault for an open antenna, not a NAV failure.
