Sync3 updating software status
Hey team. Please advise.
Ford Edge 2020, Sync3.4 19200 firmware. I played with Auto updates and added wifi, but then the connection was interrupted. But my sync repeately inform me - Update is progress, please store update to USB…etc.
I tried to update with Flash, only sync, no maps - Updating system line dissappear in 25 minutes, retry it with many usb. Then - power off, power on the engine - and again, warning from Sync - update is in progress, some function may not be available. Tried to delete gracenote - no luck.
How to drop this in-memory update process and do it from usb normally?
Old SYNC Version: 3.4.19200
New SYNC Version: 3.4.1900
“Install in progress please do not remove the USB…” message. There’s nothing in the USB port, putting the Sync update USB back in and re-running does nothing.
no logs on flash
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2000-01-04" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
  <p:VIN>2FMPK4K90LBA53484</p:VIN>
  <p:RequestRole>
  </p:RequestRole>
    <d2p1:ECUAcronym name="APIM">
      <d2p1:State>
            <d2p1:Response>5U5T-14G381-CD</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>355535542d3134473339312d434800000000000000000000345535542d3134473432332d434100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>e8724c29</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>9dca7690</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>aa2a010316022b000682</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>52530104e40340900080c005</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>0000000200</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>00000300090007</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>1ba31b9b2bc5</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>90</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>08003300000000186a00005656880070</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>DS-1U5T-14G371-EH</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>1U5T-14G380-EE</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>5U5T-14G371-CKC</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>1U5T-14G375-DA</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>WZ11FV39</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>1U5T-14G374-EH</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>90:e2:02:68:40:b3</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>90:e2:02:68:40:b4</d2p1:Response>
          </d2p1:DID>
        </d2p1:Gateway>
      </d2p1:State>
    </d2p1:ECUAcronym>
    <d2p1:AdditionalAttributes logGeneratedDateTime="2000-01-04T14:38:53+00:00" RAM="1100693504" vmcuVersion="Vector_VMCU_02.02.20">
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="10M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="14M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="13M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="11M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="879M" available="4.2M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="2.6M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.7G" available="14M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.4G" available="13M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.0G" available="12M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="1.6G" available="15M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="1.1G" available="10M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="2.5G" available="24M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="465M" available="3.0M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/grace" total="1.0G" available="57M"/>
      <d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="514M"/>
      <d2p1:PartitionHealth type="/fs/rwdata/quip/" total="90M" available="83M"/>
      <d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="144M"/>
      <d2p1:PartitionHealth type="/fs/images/" total="25G" available="4.3G"/>
      <d2p1:InstallationLog/>
      <d2p1:SyncData>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</d2p1:SyncData>
    </d2p1:AdditionalAttributes>
  </p:Node>
</p:OTAModuleSnapShot>
If you can go here https://www.ford.com/support/sync-maps-updates/
Download the update file and put it directly on the usb and plug it in and see if it brute force goes
Edit:
I forgot to add make sure the two files stay outside the folder I’ve had some goofs where they pop into it when I move them
Hi.
It’s not clear what you want to do (or what you have done).
Have you master reset?.
Provide the log for that USB.
You don’t, disable OTA updates.
Thank you all! Master reset did the trick.
Successfully updated Sync.
Jailbreaked and deleted US maps, installed EU maps instead:)
Next challenge - make UK TCU work in UA
