You say you have a new battery. Is it identical to the original or is it a close substitute? Did you change battery types from AGM to standard, or vice versa?
It’s like for like. I did a Battery Management Reset and now it’s seems to be functioning properly. Stop Start is ok at the moment an dthe heated windscreen is working. Thanks
My Forscan Cable should be here in a few days.
