Ahmad123
(Ahmad123)
August 4, 2025, 9:31pm
1
Hello CyanLabs community,
I’m currently working on recovering a soft-bricked TCU (Telematic Control Unit) in my 2020 Ford Fusion SE EcoBoost.
Details:
• TCU Part Number: LB5T-14G087-SE
• Calibration Level: LB5T-14G087-SE
• Issue: TCU is detected in FORScan but modem serial (ESN) is missing, FordPass Connect not working.
• Need: Looking for the VBF firmware files (strategy/calibration) for this TCU to manually reflash.
I’ve tried TCU module resets and As-Built edits. FORScan does not offer the “Firmware Update” option, so I need the VBF files to attempt a manual flash.
If anyone has these files or can point me where to get them, I would greatly appreciate it.
Thanks in advance for your help!
F150Chief
(F150Chief)
August 5, 2025, 2:23am
2
Did you make the appropriate asbuilt adjustments to the modules?
Sync Connect APIM & TCU Programming and Activating.pdf (520.8 KB)
You will need a paid version of FORScan for module firmware programming.
Added notes below for purchasing the Extended License.
FORScan 2.4.18 is a public release.
Link to download v2.4.18 beta
Changelog (full change history can be found in FORScan.Changelog.2.4.txt available in the FORScan installation folder):
2.4.18 beta, 2025-05-16
v2.3.66 functionality
Firmware database update
Support Black OAK/Green OAK 448/512K TCM programming on 2003-2007 F-Series/E-Series (experimental!)
bug: incorrect recognition HEX/PHF files in some cases
You must obtain a paid lic…
Ahmad123
(Ahmad123)
August 5, 2025, 2:47am
3
I have the payed version and everything,
There’s a switch somewhere withing the programming interface that forces suspension of other devices on the bus, i’m not sure if that applies here.
F150Chief
(F150Chief)
August 5, 2025, 2:56am
5
What files are you trying to load? The SBL is either wrong or missing.. Can you see the asbuilt and what firmware files are currently loaded?
F150Chief
(F150Chief)
August 5, 2025, 2:57am
6
Most of the time you don’t need to silence the busses, but in certain cases yes, especially for the APIM and BCM. This won’t load the SBL, so there is a different issue.
Ahmad123
(Ahmad123)
August 5, 2025, 3:09am
7
Im trying to upload the pictures
Ahmad123
(Ahmad123)
August 5, 2025, 3:12am
9
I updated the APIM and it worked but the TCU isn’t working at all, its giving me hard time to know what’s preventing it from updating or functioning
F150Chief
(F150Chief)
August 5, 2025, 3:13am
10
Unplug the power connector from the TCU for a few minutes then reconnect and try again.
Ahmad123
(Ahmad123)
August 5, 2025, 3:14am
11
I did that, i removed everything and then plugged it in nothing happened
F150Chief
(F150Chief)
August 5, 2025, 3:17am
12
Can you access the asbuilt?
Is this the original TCU for the vehicle?
Ahmad123
(Ahmad123)
August 5, 2025, 3:18am
13
Yes its the original it was functioning properly couple months ago, but suddenly disconnected
F150Chief
(F150Chief)
August 5, 2025, 3:21am
14
That TCU might have issues. These usually work right.
Ahmad123
(Ahmad123)
August 5, 2025, 3:27am
16
I think its not letting me access anything regarding TCU
Ahmad123
(Ahmad123)
August 5, 2025, 3:36am
18
I can order a new one and then program it on the cars vin right?
Ahmad123
(Ahmad123)
August 5, 2025, 3:53am
20
Thankyou so much for ur help
