The selected XML file does not contain a valid "ECU Delivery Assembly
Hi Guys
Can you help me with updating my sync 3?
Error in the description. XML file atttached.
Thank you so much!
Old SYNC Version: 3.4.21194
Error
The selected XML file does not contain a valid “ECU Delivery Assembly
Number”. It is therefore not possible to determine whether it is a My20+
APIM or not,
Create a post in the Community Forum or our Discord to determine how to proceed.
determine how to proceed,
STOP! DO NOT PROCEED WITHOUT THE HELP OF AN EXPERT!
Syn3 Updater Version: 2.12.2.0 Stable
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2023-12-28" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
  <p:VIN>xxx</p:VIN>
  <p:RequestRole>
  </p:RequestRole>
  <p:BroadcastDTCType/>
    <d2p1:ECUAcronym name="APIM">
      <d2p1:State>
            <d2p1:Response>NU5T-14G381-AB</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>315535542d3134473432312d424148000000000000000000315535542d3134473432312d424248000000000000000000315535542d3134473432312d424348000000000000000000315535542d3134473432312d424448000000000000000000315535542d3134473432312d424548000000000000000000315535542d3134473432312d424648000000000000000000315535542d3134473432312d424748000000000000000000315535542d3134473432312d424848000000000000000000315535542d3134473432312d424a48000000000000000000315535542d3134473635382d414800000000000000000000345535542d3134473432322d424146000000000000000000345535542d3134473432322d424246000000000000000000345535542d3134473432322d424346000000000000000000345535542d3134473432322d424446000000000000000000345535542d3134473432332d414300000000000000000000355535542d3134473339312d415400000000000000000000</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>N0CF02QS</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>6c:79:b8:6e:da:b3</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>6c:79:b8:6e:da:b4</d2p1:Response>
          </d2p1:DID>
        </d2p1:Gateway>
      </d2p1:State>
    </d2p1:ECUAcronym>
    <d2p1:AdditionalAttributes logGeneratedDateTime="2023-12-28T13:37:58+00:00" RAM="1075998720" vmcuVersion="Vector_VMCU_02.02.20">
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="892K"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.8G" available="14M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.3G" available="14M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="7.9M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.2G" available="17M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.7G" available="21M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="38M" available="396K"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.2G" available="5.7M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.1G" available="24M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="4.7G" available="27M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="4.9G" available="29M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="4.3G" available="25M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="3.6G" available="35M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/grace" total="1003M" available="21M"/>
      <d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="358M"/>
      <d2p1:PartitionHealth type="/fs/rwdata/quip/" total="90M" available="88M"/>
      <d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="84M"/>
      <d2p1:PartitionHealth type="/fs/mp/resources" total="72M" available="332K"/>
      <d2p1:PartitionHealth type="/fs/images/" total="54G" available="11G"/>
      <d2p1:InstallationLog/>
      <d2p1:SyncData>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</d2p1:SyncData>
    </d2p1:AdditionalAttributes>
  </p:Node>
</p:OTAModuleSnapShot>
Hello.
I wonder: why do you care about that?.
Your car was made in 2022 according to your profile, so it’s MY20. The APIM model is kind of irrelevant. Keep MY20 protection enabled at all times.
Nothing to do, if the APIM does not present itself while running the interrogator log the only way for you to check that value would be via Forscan or by removing the unit and checking the sticker. I think you could also look into bezel diagnostics, but I’m not 100% sure.
If the unit is running 3.4, you could also try upgrading to the latest 3.4 without upgrading maps.
That’s an autoinstall installation which is safe, and maybe the latest 3.4 will respond correctly to the interrogator log.
Thanks. I Will try. I was confused by the red warning message and thought there might be something else
:+1:
But you got that screen because you told Syn3Updater you were not sure if your unit is MY20 or not… If you had answered that correctly, you would not have seen that warning…
So, keep MY20 protection active, only autoinstalls can be ran against the unit, do not reformat it.
Understood. Thanks
