Do you have a error message, if so what is it? “The wrong diskette is in the drive. Insert %2 (Volume Serial number %3) into drive %1.”
Log file is not generated, however I managed to grab a photo of the exact error here.
I get the error about 70% during the install process (in the file copying phase), I am using latest syn3 updater 2.7.3. I am using a 64gb exfat formatted (within the app) usb stick.
This is not an issue with Syn3 Updater, either your USB drive is fake, or something happened to the USB while the process was running (Ryzen 3000 CPU’s for example have some known USB issues which are fixed in BETA bioses released by most manufacturers)
