Trying to find APIM Calibration Files for Pre-18.5MY
I apologize if I somehow missed these in my search, but trying to find the files to upgrade my Pre-18.5 APIM.
3.0 APIM NAV & NON-NAV Unit Firmware (Production Release, 2017-Pre-2018.5, H thru Early J Series)
Calibration (F124): HB5T-14G375-DA or HB5T-14G375-FA (NAV)
I have all the other files, just need the Calibration for NAV unit as above. THANKS!
Old SYNC Version: 2.2
New SYNC Version: 3.4188
None
Syn3 Updater Version: 2.13
N/A
You don’t change your calibration for NAV, to enable it in the APIM menus its a bit change with ForScan.
That said NAV APIMs have more storage space in order to hold the map files than non-NAV APIMs, in the case of an NA unit the standard APIM has 8Gb while a NAV has 32Gb.
Understand. It’s a 32GB NAV APIM and for whatever reason if I’m letting Forescan do its thing it only brings up calibration file for non-NAV unit. So, just needing to swap that one file, the rest of what Forescan pulls is the recommended for the unit I have.
FOUND. Thank you all
