Trying to update from an old version
Hi guys, I am trying to update my Sync 3 to the latest version, but it has not been done in a very long time, and I’m struggling and could use some assistance. The version that is currently installed is 2.0.16074, and the Ford website says I can update to 3.0.23219. I have downloaded the package from Ford, followed their instructions to put it on a USB stick, and had it saying it was updating for over an hour with no luck.
I read that Cyanlabs was a way forward, so have downloaded the software to make a USB stick to do it, but my old version isn’t shown as an option, so have got stuck at that point.
Any ideas on how I can update it, it works like a piece of garbage at the minute, I have to reset it 2 or 3 times a journey, which is pretty annoying!
Old SYNC Version: 2.0.16074
New SYNC Version: 3.0.23219
No error messages, just doesn’t update
Hello.
Before moving forward, configure Syn3updater with your current build (if it’s not there, just type it).
Then, create an interrogator log and run it against the unit.
You must endure car play works before going to 3.4, we will get to that.
For now, try the interrogator log.
Also, what’s your end goal?.
Hi Sandman,
Thanks for coming back to me, my end goal is to have a more up to date unit, it doesn’t need to be the latest, I’m hoping that updating it will stop it randomly not seeing my iphone, or losing DAB radio.
I didn’t know I could type my number in, I will go ahead and try that.
Thank you!
Update, I followed some tips from this forum, and was able to update from the old version I had to 3.0.23219.
I reformatted the USB to FAT32 rather than exfat as Ford had recommended, and did a master reset before I started. I then plugged it in when I had a long drive, and it updated in about 40 minutes.
Initially, it was great, it was all working like new and I was happy with it. However, later in the day it went back to working badly, in fact worse than before. The on-screen buttons are very laggy, and if I get a call, it doesn’t stop the radio.
Any idea if updating to a newer version would be any help, or is it the unit itself that is in need of replacement?
There is no guarantee that upgrading to 3.4 will change that behavior. I almost suspect your APIM may be going bad, and depending on what the peoblem is, upgrading it to 3.4 may do it in.
On the other hand, if this is caused by bad memory blocks on your emmc then a reformat which is required for the upgrade could help for a while until the emmc acquires more bad blocks.
Hard to say, I’m still waiting on the interrogator log output. :roll_eyes:
What map version is the unit running?.
Depending on what you installed, 40 minutes seems a lot of time…
Here is the interrogator log.
I was on a long drive yesterday, it was still playing up
Sync_MV9V008G_6FPPXXMJ2PGS30155.xml (10.7 KB)
You have very old maps on the unit, there’s a known incompatibility between the latest 3.0 builds and old maps.
Follow the “Sync 3.0.20204/23219 with EU 2.21 (F11) or EU 2.22 (F12) or EU 2.23 (F13)/EU 2.24 (F14) Map Installation” guide to update maps and report back.
Ok cool, will do.
Hi Sandman,
I followed the instructions on the link you put, and the issues I was having are pretty much gone, there’s now no lag, and I don’t have to restart it to get my phone to work!
Here’s the interrogator log following the latest updates, could you have a quick look sometime for me?
Sync_MV9V008G_6FPPXXMJ2PGS30155.xml (10.1 KB)
That log does not seem correct, maps are quite old and you have a lot of free space on the APIM… Have you followed the guide?.
I mean, if your original issues are solved that’s great, but I do not see the latest EU maps installed…
Yes, I followed that guide to the letter, it is occasionally throwing up a message saying it’s still installing, even though no USB stick is plugged in. When I look at the “about sync” page within the settings, it says the map version is F11, but it doesn’t have version info about Gracenote, so I think that bit failed somehow.
I’m a little tempted to install the F14 map pack tbh
Then there’s something that’s not correctly installed. I would advise to install all the latest packages. If you are upgrading there’s no reason for not going to the latest packages.
Will do, I’ll go for the latest packages and let you know how it goes
Thanks for all the help so far! :slight_smile:
