so I spent most of the day trying to get the ford sync downloader to work with no success. I kept getting an error message stating that Windows would have to force close the program because it was unresponsive. I believe I saw that someone else had this same problem.
So since the downloader wasn’t working, I went through the manual process.
Followed the instructions that were given & with the USB installed into the vehicle I began the update process and then I got this error message.
I used NA for region
Chose 3.4 19200
I currently have Navigation, so i chose i have navigation
Then downloaded & copied everything listed
Please advise because it’s been on this screen now for 1hr 40mins and nothing has happened
since it says Error in BLANK you have a issue either with a missing reformat.lst, maybe named reformat.lst.txt or you have a mistake in the reformat.lst
Autoinstall.lst is irrelevant at this point
And don’t panic this is completely recoverable once we determine where the mistake is.
In the US
2017 Ford Fusion Sport.
Stock unit that came with the car to my knowledge
The contents of the autoinstall.lst are the contents that i assume came with the download that’s listed in step 1 of the manual method.
Item1 = 1U5T-14G386-CB - SyncMyRide\1U5T-14G386-CB.tar.gz
Open1 = SyncMyRide\1U5T-14G386-CB.tar.gz
so i assume once i fix the issue with the reformat/syncmyride folder, all i need to do is stick the USB drive back into the car & it should start the process again?
Yes. Even if it does the reformat again, there is nothing there. It should pick up and the screen should show the backgrounds and start processing the files. It will take just short of 30 minutes. Do not remove the USB until Sync reboots, then let the system boot and process, takes a few minutes. NAV will take the longest but the rest of the system will come up pretty quick.
Not sure to be honest. When I did the 1st attempt I recall there were 13 total files & 13 files on the notepad doc.
Alas the 2nd attempt worked perfectly. I actually went ahead and went with the most recent 3.4 file instead of 19200 because I don’t play music through USB so why not have the most recent version.
All of it could of been avoided if I could of gotten the sync downloader to work. Not sure why it wouldn’t work for me, but I’m kind of glad I had to do the manual method. I feel like I learned more that way.
Thanks again for the help! Much appreciated.
