What is your SYNC Region?
EU
What was your Old SYNC Version?
3.0 20204
3.0 20204
Do you have Navigation?
Yes
Have you read the documentation at Syn3 Updater Documentation - CyanLabs ?
Yes
---- Unable to read data from the transport connection.
PASTE LOG HERE
I have attemped to install the update, from 3.0 to 3.4, along with maps, and I am presented with the ‘Unable to read data from the transport connection.’ message. I press ok, then it goes back to the start and tells me the downloads have been skipped.
Any help would be greatly appreciated!
Thanks!
Let’s say it’s not an app related issue, but related to the connection you are using, or Ford’s servers.
What you can try is to manually download the files, save those into the Syn3Updater folder, and then run the program again: it won’t download the files again if they are found, it will validate them and then create the USB.
Web browsers can handle unhealthy connections better.
Hey, guys, thank you for the great help so far!
I’ve managed to install the latest Sync 3.4 (without satellite navigation) however, it’s fired up all nice and lovely, looks brilliant, but my navigation now doesn’t work??
It was working perfectly before, does this mean I have to install the new maps along with the Sync update?
If I understand correctly, you went from 3.0 with nav to 3.4 without nav, right?.
If so, that’s exactly why your nav does not work: you didn’t install maps.
Yes, my own fault for not reading it through correctly!
I have downloaded all the files once again, including the navigation this time, and am praying it’ll fix itself tomorrow - really hoping I don’t have to downgrade and do it a third and fourth time!
If your unit is not MY20 (if you had 3.0, it’s not originally MY20), I would downgrade and then reformat again with maps. Autoiinstall MAP for EU will take forever…
But, that’s up to you.
No no, that’s fine, and I’m sorry if it seems like I’m worrying, or asking far too many questions,
I’d just rather be 100% certain before I get to the point of no return.
