Unable to upgrade sync 3 1.0 to 3.4
so i have a new to me 2016 f150 XLT with a sync 3 system that is still running 1.0.15139 and I am trying to update to 3.4 so i can get carplay to work with my new USB hub. but when i attempted to run the update nothing changed and i got the following message:
Error
The XML file you have selected does not contain the expected output
Syn3 Updater has determined you are on 1.0.15139 and may be using overlays
Syn3 Updater is unable to determine the configuration of your APIM
Please request assistance on our forum at https://community.cyanlabs.net
so any direction on next steps would be apprieciated.
also it appears the previous owner had ford replace the screen in april of 22 if that matters.
Old SYNC Version: 1.0.15139
New SYNC Version: 1.0.15139
Error The XML file you have selected does not contain the expected output Syn3 Updater has determined you are on 1.0.15139 and may be using overlays Syn3 Updater is unable to determine the configuration of your APIM Please request assistance on our forum at https://community.cyanlabs.net
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2005-08-24" xsi:schemaLocation="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0 ModuleSnapshot.xsd">
<p:VIN>1FTFW1EF9GFC57290</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType>
  <d2p1:DTC DTCValue="e0175108"/>
  <d2p1:DTC DTCValue="f000040b"/>
</p:BroadcastDTCType>
  <d2p1:ECUAcronym name="APIM">
    <d2p1:State>
          <d2p1:Response>GB5T-14G381-AN</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>4a5233542d3134473339312d424600000000000000000000474235542d3134473432312d454800000000000000000000474235542d3134473432342d444800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
          <d2p1:Response>a836fb16</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>04d14392</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>2a2a0406000089060482</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>55530103c402028000000000</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>0000010300</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>01000001000001</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>1a681a683d54</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
          <d2p1:Response>47003300000000029a000056569400c8</d2p1:Response>
        </d2p1:DID>
        <d2p1:DID didType="Direct Configuraation DID DE07" didValue="DE07">
        </d2p1:DID>
        <d2p1:DID didFormat="ASCII" didType="ECU Cal-Config Part Number" didValue="F10A" responseLength="24">
        </d2p1:DID>
          <d2p1:Response>DS-GB5T-14G371-AF</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>GJ5T-14G380-AC</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>GJ5T-14G371-BFC</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>GB5T-14G375-BA</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>VV5E4DX8</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
        </d2p1:DID>
        <d2p1:DID didFormat="ASCII" didType="ECU Cal-Config #2 Part Number" didValue="F16B" responseLength="24">
        </d2p1:DID>
          <d2p1:Response>GB5T-14G374-AF</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
          <d2p1:Response>80:30:dc:b0:3c:f5</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>80:30:dc:b0:3c:f6</d2p1:Response>
        </d2p1:DID>
      </d2p1:Gateway>
    </d2p1:State>
  </d2p1:ECUAcronym>
  <d2p1:ODLNetwork d2p1:NetworkDataRate="500" d2p1:NetworkName="HS1" d2p1:NetworkProtocol="CAN" d2p1:DLCName="SAE J1962" d2p1:Pins="6,14"/>
  <d2p1:AdditionalAttributes logGeneratedDateTime="2005-08-24T13:23:40+00:00" RAM="1234567" vmcuVersion="Vector_VMCU_02.02.20">
    <d2p1:PartitionHealth type="/fs/usb0/" total="57G" available="57G"/>
    <d2p1:InstallationLog/>
    <d2p1:SyncData>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</d2p1:SyncData>
  </d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Someone has really messed up this Sync APIM. Since GJ5T-14G371-BFC - NON Navigation, you might be better off sourcing a newer unit, as this one will need to have the firmware reloaded, replacing the GB5T-14G374-AF file and reloading all of the software. It will need to be reformatted to clear the maps that were loaded and not compatible, and the Sync 3.2 voice file that was loaded somehow. The unit only has 8GB of storage.
Installed on the APIM:
GB5T-14G381-AN Sync 1.0.15139 Sync app.
JR3T-14G391-BF Sync 3.2.19137-Pre18.5 Voice file
GB5T-14G421-EH Maps
GB5T-14G424-DH Map License file.
No Overlays.
From the OEM asbuilt:
7D0 APIM
F110>DSGB5T-14G371-AF
F111>GJ5T-14G380-AC
F113>GJ5T-14G371-BFC Non-Nav
F124>GB5T-14G375-BA
F141>VV5E4DX8
F188>GB5T-14G374-AF
F18C>�����������
F1D0>80:30:DC:B0:3C:F5
F1D1>8030DCB03CF6
Corrupted firmware addresses.
APIM Asbuilt:
7D0-01-01 2A2A 0406 0037
7D0-01-02 0089 0604 82EF
7D0-02-01 5553 0103 C44A
7D0-02-02 0202 8000 005F
7D0-02-03 0000 DC
7D0-03-01 0000 0103 00DF
7D0-04-01 0100 0001 00DE
7D0-04-02 0001 DE
7D0-05-01 1A68 1A68 3D1E
7D0-05-02 5432
7D0-06-01 805E
7D0-07-01 4700 3300 0059
7D0-07-02 0000 029A 007C
7D0-07-03 0056 5694 0021
7D0-07-04 C8AA
7D0-08-01 0000 0000 00E0
7D0-08-02 0000 0000 00E1
Interesting, well right after i asked the question i came across the suggestion to do the 2.2 upgrade first, so i gave that a shot and it was effective. so i went for it with the latest 3.4 and it worked! so hello carplay! my screen is now more than a giant bright clock.
so somewhere between those 2 updates it reformatted what was necessary.
That’s good that it worked. It was reformatted on the 3.4 upgrade, so the map file should be gone.
