Update both Sync and Map versions
Hello
I use Sync 3.4 on a European 2018 Ecosport but I am lacking behind in build 20282 and Maps F9 version.
Which shall I update first?
Maps (F9 → F12) or
Build (20282 → 23188)
I feel that Updating both at the same time seems more tricky, so just wondering which is less pain: update first build and then maps or vise vers.
Thanks in advance
Cris
Old SYNC Version: 3.0.19205
New SYNC Version: 3.4.20282
NO
 Not available for the moment
I always do both at the same time. Takes and hour for NA maps. You might be 2 hours for EU maps.
You are giving contradictory information…
Having said that, if you can reformat (not MY20 APIM) your unit do everything at once…
Please help me to understand which info is contradictory:
I have build 3.4.20282 and EU maps F9 and
want to upgrade to 23188 and EU maps F12.
Here’s how things can go badly wrong, if you don’t set things up right.
Ok I see your point.
Apart from this do you think upgrading build and maps in different steps makes sense and if yes whixh is the best way to go? First build and then maps or vise versa?
Thanks again
Doing it in 2 stages makes zero sense, if you are confident you DON’T have a MY20 unit then use reformat method to update the whole hog in one hit.
Thanks.
My Ecosport is a 2018 model,
Hope everything goes well.
Cris
