Good morning.,
I’m pretty new to your site, thank you in advance for your welcome…
I own a Kuga st line 2018, sync version 3.4 20196 and F9 EU navigation maps.
I want to upgrade to F10 EU cards.
Is it possible, if so, what should I do ?
Thank you !!
Hello.
I’ve separated your message into a new thread, since you posted it in an unrelated old topic. In the future, please be mindful of what and where you post, help us keeping the forums clean and organized.
If you want to upgrade, you should start by reading the tutorial , it’s quite straight forward: Easily Update SYNC 3 Using Our Automated Method - CyanLabs
All information you need is there.
Yes, there is plenty of documentation on this site, please look around.
ok, bien compris encore désolé pour le dérangement!!
Merci pour la réponse rapide.
J’ai consulté la documentation et maintenant c’est plus clair. Il me reste cependant une question:
puis-je conserver la version sync 3.4 20196 pour la mise à jour des cartes ( F9 à F10 ) ou dois je choisir une autre version?
Si oui laquelle me conseillez-vous, votre réponse est importante car je ne suis pas un expert comme vous!
Merci encore pour votre patience, votre investissement personnel et la qualité de votre travail !!
okay, well understood again sorry for the inconvenience!!
Thanks for the quick response.
I looked at the documentation and now it’s clearer. I still have a question:
can I keep sync version 3.4 20196 for updating maps (F9 to F10) or do I have to choose another version?
If yes which one do you advise me, your answer is important because I am not an expert like you!
Thank you again for your patience, your personal investment and the quality of your work !!
You can stay at that build or choose a newer one, but you can’t just update maps.
I’m saying this because whatever version you choose to remain on, as long as you choose maps, it will be overwritten nonetheless. Of course you can select your current and desired version to be the same, so that you stay at 20196…
If you ask me, I would go to the latest build which is only a few months old.
This, as it’s recent, has a lot of bugs fixed and other improvements.
Just make sure to configure the tool correctly, setting your current version, region and navigation in the Settings tab, and then the desired configuration at the Home tab.
Hello,
thanks for your answer, can you tell me which sync version you advise me,
sync 3.4 build version?
I’m a little lame and I’m afraid to crash the system… Thank you again for your patience !!! :
3.4.21020 is the latest available.
FYI, the naming convention is 3.4.yyddd, yy being the year and ddd the day (0-365/366)
So 21020 is from the Jan 20th 2021, quite recent.
The USB flash drive is ready for use. I got the following report . Can I start the system update in the car?
Thank you!!
Version: 3,4,20196
Mode: downgrade
Model: Kingston HyperX Savage USB Device 58,6GB
VOICE=5U5T-14G391-AN_1615393794000.TAR.GZ
GRACENOTES=4U5T-14G423-AB_1598633764000.TAR.GZ
APPS=5U5T-14G381-ER_1615427592000.TAR.GZ
; CyanLabs Syn3Updater 2.x - downgrade Mode - Sync 3.4.21020 EU
FILES (21)
1u5t-14g386-cb.tar.gz (8,5MB)
5U5T-14G391-AN_1615393794000.TAR.GZ (1,5GB)
1U5T-14G658-AF_1598633324000.TAR.GZ (58,8MB)
4U5T-14G423-AB_1598633764000.TAR.GZ (684,9MB)
5U5T-14G381-ER_1615427592000.TAR.GZ (847,1MB)
4U5T-14G422-BCF_1615431448000.TAR.GZ (1,6GB)
4U5T-14G422-BBF_1615431222000.TAR.GZ (2,2GB)
4U5T-14G422-BAF_1615431156000.TAR.GZ (2,3GB)
[06/04/2021 17:29:24] Selected Region: EU - Release: Sync 3.4.21020 - Map Version: F10 (2020) - EU (03 2021)
[06/04/2021 17:29:24] Install Mode: downgrade
[06/04/2021 17:29:24] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[06/04/2021 17:29:34] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[06/04/2021 17:29:34] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[06/04/2021 17:29:34] Validated: GB5T-14G386-SC_85041.tar.gz (Skipping Download)
[06/04/2021 17:29:34] Checking Existing File: 1u5t-14g386-cb.tar.gz
[06/04/2021 17:29:34] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[06/04/2021 17:29:34] Checking Existing File: 5U5T-14G391-AN_1615393794000.TAR.GZ
[06/04/2021 17:29:49] Validated: 5U5T-14G391-AN_1615393794000.TAR.GZ (Skipping Download)
[06/04/2021 17:29:49] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[06/04/2021 17:29:50] Validated: 1U5T-14G658-AF_1598633324000.TAR.GZ (Skipping Download)
[06/04/2021 17:29:50] Checking Existing File: 4U5T-14G423-AB_1598633764000.TAR.GZ
[06/04/2021 17:29:57] Validated: 4U5T-14G423-AB_1598633764000.TAR.GZ (Skipping Download)
[06/04/2021 17:29:57] Checking Existing File: 5U5T-14G381-ER_1615427592000.TAR.GZ
[06/04/2021 17:30:05] Validated: 5U5T-14G381-ER_1615427592000.TAR.GZ (Skipping Download)
[06/04/2021 17:30:05] Checking Existing File: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[06/04/2021 17:30:24] Validated: 1U5T-14G421-BGH_1615430797000.TAR.GZ (Skipping Download)
[06/04/2021 17:30:24] Checking Existing File: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[06/04/2021 17:30:28] Validated: 1U5T-14G421-BBH_1615430406000.TAR.GZ (Skipping Download)
[06/04/2021 17:30:28] Checking Existing File: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[06/04/2021 17:30:29] Validated: 1U5T-14G421-BJH_1615431074000.TAR.GZ (Skipping Download)
[06/04/2021 17:30:29] Checking Existing File: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[06/04/2021 17:30:54] Validated: 1U5T-14G421-BHH_1615430859000.TAR.GZ (Skipping Download)
[06/04/2021 17:30:54] Checking Existing File: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[06/04/2021 17:31:24] Validated: 1U5T-14G421-BFH_1615432204000.TAR.GZ (Skipping Download)
[06/04/2021 17:31:24] Checking Existing File: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[06/04/2021 17:31:36] Validate: 1U5T-14G421-BEH_1615430614000.TAR.GZ (Failed!, Downloading)
[06/04/2021 17:31:36] Downloading: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[06/04/2021 17:38:34] Validating: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[06/04/2021 17:38:50] Downloaded: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[06/04/2021 17:38:50] Checking Existing File: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[06/04/2021 17:38:50] Downloading: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[06/04/2021 17:43:55] Validating: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[06/04/2021 17:44:00] Downloaded: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[06/04/2021 17:44:00] Checking Existing File: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[06/04/2021 17:44:00] Downloading: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[06/04/2021 17:52:35] Validating: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[06/04/2021 17:52:52] Downloaded: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[06/04/2021 17:52:52] Checking Existing File: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[06/04/2021 17:52:52] Downloading: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[06/04/2021 18:04:11] Validating: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[06/04/2021 18:04:37] Downloaded: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[06/04/2021 18:04:37] Checking Existing File: 1U5T-14G424-BK_1616682400000.TAR.GZ
[06/04/2021 18:04:37] Downloading: 1U5T-14G424-BK_1616682400000.TAR.GZ
[06/04/2021 18:04:38] Validating: 1U5T-14G424-BK_1616682400000.TAR.GZ
[06/04/2021 18:04:38] Downloaded: 1U5T-14G424-BK_1616682400000.TAR.GZ
[06/04/2021 18:04:38] Checking Existing File: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[06/04/2021 18:04:38] Downloading: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[06/04/2021 18:09:55] Validating: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[06/04/2021 18:10:16] Downloaded: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[06/04/2021 18:10:16] Checking Existing File: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[06/04/2021 18:10:16] Downloading: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[06/04/2021 18:14:17] Validating: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[06/04/2021 18:14:33] Downloaded: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[06/04/2021 18:14:33] Checking Existing File: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[06/04/2021 18:14:33] Downloading: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[06/04/2021 18:21:04] Validating: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[06/04/2021 18:21:25] Downloaded: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[06/04/2021 18:21:25] Checking Existing File: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[06/04/2021 18:21:25] Downloading: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[06/04/2021 18:27:47] Validating: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[06/04/2021 18:28:08] Downloaded: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[06/04/2021 18:28:08] Preparing USB drive
[06/04/2021 18:28:08] Formatting USB drive
[06/04/2021 18:28:08] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[06/04/2021 18:28:16] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[06/04/2021 18:28:16] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[06/04/2021 18:28:29] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[06/04/2021 18:28:31] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[06/04/2021 18:28:31] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[06/04/2021 18:28:31] Copying: GB5T-14G386-SC_85041.tar.gz
[06/04/2021 18:28:31] Validating: GB5T-14G386-SC_85041.tar.gz
[06/04/2021 18:28:31] Copied: GB5T-14G386-SC_85041.tar.gz
[06/04/2021 18:28:31] Checking Existing File: 1u5t-14g386-cb.tar.gz
[06/04/2021 18:28:31] Copying: 1u5t-14g386-cb.tar.gz
[06/04/2021 18:28:31] Validating: 1u5t-14g386-cb.tar.gz
[06/04/2021 18:28:31] Copied: 1u5t-14g386-cb.tar.gz
[06/04/2021 18:28:31] Checking Existing File: 5U5T-14G391-AN_1615393794000.TAR.GZ
[06/04/2021 18:28:31] Copying: 5U5T-14G391-AN_1615393794000.TAR.GZ
[06/04/2021 18:29:03] Validating: 5U5T-14G391-AN_1615393794000.TAR.GZ
[06/04/2021 18:29:08] Copied: 5U5T-14G391-AN_1615393794000.TAR.GZ
[06/04/2021 18:29:08] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[06/04/2021 18:29:08] Copying: 1U5T-14G658-AF_1598633324000.TAR.GZ
[06/04/2021 18:29:10] Validating: 1U5T-14G658-AF_1598633324000.TAR.GZ
[06/04/2021 18:29:10] Copied: 1U5T-14G658-AF_1598633324000.TAR.GZ
[06/04/2021 18:29:10] Checking Existing File: 4U5T-14G423-AB_1598633764000.TAR.GZ
[06/04/2021 18:29:10] Copying: 4U5T-14G423-AB_1598633764000.TAR.GZ
[06/04/2021 18:29:24] Validating: 4U5T-14G423-AB_1598633764000.TAR.GZ
[06/04/2021 18:29:26] Copied: 4U5T-14G423-AB_1598633764000.TAR.GZ
[06/04/2021 18:29:26] Checking Existing File: 5U5T-14G381-ER_1615427592000.TAR.GZ
[06/04/2021 18:29:26] Copying: 5U5T-14G381-ER_1615427592000.TAR.GZ
[06/04/2021 18:29:42] Validating: 5U5T-14G381-ER_1615427592000.TAR.GZ
[06/04/2021 18:29:45] Copied: 5U5T-14G381-ER_1615427592000.TAR.GZ
[06/04/2021 18:29:45] Checking Existing File: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[06/04/2021 18:29:45] Copying: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[06/04/2021 18:30:25] Validating: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[06/04/2021 18:30:32] Copied: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[06/04/2021 18:30:32] Checking Existing File: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[06/04/2021 18:30:32] Copying: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[06/04/2021 18:30:42] Validating: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[06/04/2021 18:30:43] Copied: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[06/04/2021 18:30:43] Checking Existing File: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[06/04/2021 18:30:43] Copying: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[06/04/2021 18:30:44] Validating: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[06/04/2021 18:30:44] Copied: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[06/04/2021 18:30:44] Checking Existing File: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[06/04/2021 18:30:44] Copying: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[06/04/2021 18:31:37] Validating: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[06/04/2021 18:31:47] Copied: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[06/04/2021 18:31:47] Checking Existing File: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[06/04/2021 18:31:47] Copying: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[06/04/2021 18:32:36] Validating: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[06/04/2021 18:32:45] Copied: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[06/04/2021 18:32:45] Checking Existing File: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[06/04/2021 18:32:45] Copying: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[06/04/2021 18:33:20] Validating: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[06/04/2021 18:33:26] Copied: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[06/04/2021 18:33:26] Checking Existing File: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[06/04/2021 18:33:26] Copying: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[06/04/2021 18:33:48] Validating: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[06/04/2021 18:33:52] Copied: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[06/04/2021 18:33:52] Checking Existing File: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[06/04/2021 18:33:52] Copying: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[06/04/2021 18:34:27] Validating: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[06/04/2021 18:34:34] Copied: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[06/04/2021 18:34:34] Checking Existing File: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[06/04/2021 18:34:34] Copying: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[06/04/2021 18:35:22] Validating: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[06/04/2021 18:35:31] Copied: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[06/04/2021 18:35:31] Checking Existing File: 1U5T-14G424-BK_1616682400000.TAR.GZ
[06/04/2021 18:35:31] Copying: 1U5T-14G424-BK_1616682400000.TAR.GZ
[06/04/2021 18:35:31] Validating: 1U5T-14G424-BK_1616682400000.TAR.GZ
[06/04/2021 18:35:31] Copied: 1U5T-14G424-BK_1616682400000.TAR.GZ
[06/04/2021 18:35:31] Checking Existing File: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[06/04/2021 18:35:31] Copying: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[06/04/2021 18:36:11] Validating: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[06/04/2021 18:36:18] Copied: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[06/04/2021 18:36:18] Checking Existing File: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[06/04/2021 18:36:18] Copying: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[06/04/2021 18:36:52] Validating: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[06/04/2021 18:36:58] Copied: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[06/04/2021 18:36:58] Checking Existing File: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[06/04/2021 18:36:58] Copying: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[06/04/2021 18:37:41] Validating: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[06/04/2021 18:37:48] Copied: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[06/04/2021 18:37:48] Checking Existing File: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[06/04/2021 18:37:48] Copying: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[06/04/2021 18:38:33] Validating: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[06/04/2021 18:38:41] Copied: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[06/04/2021 18:38:41] Generating reformat.lst
[06/04/2021 18:38:41] Generating autoinstall.lst
[06/04/2021 18:38:41] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Thank you!!
That looks good.
Make sure to follow the tutorial described in the previously given link.
What you need to do is contained in “Updating (Downgrade Mode)”, since downgrade is the required method chosed by the tool.
Okay, I’ll try tomorrow morning and then I’ll let you know the result.
I hope not to encounter problems because I am not too good at IT.
Good evening.
hello
I just finished the installation (1 hour) in the kuga and everything seems to work perfectly !!
Thank you very much for your help and work !
Glad to hear, enjoy it!
