Hi!
I updated from original SYNC3 OS to 3.4.21265 some months ago, now I wanted to update again to the last version but when I power on engine and connect the USB, appears the message “updating”, but nothing has happened in about 40 minutes…
I has powered off engine, disconnect USB, power on again and SYNC3 has start normally, I hope tomorrow all will be ok too.
What I can be doing wrong? When I did the first update I think all be the same…
Thanks!
Old SYNC Version: 3.4.21265
New SYNC Version: 3.4.22251
The updating message appears, but doesn’t do anything in about 40 minutes. I have power off car, disconnect USB, start again and everything has start correctly.
The problem is that I can’t update.
Version: 3.4.21265
FileSystem: FAT32
; CyanLabs Syn3Updater 2.11.8.0 Stable - Autoinstall Mode - Sync 3.4.22251 EU
Item1 = VOICE - 5U5T-14G391-AT_1660763323000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G391-AT_1660763323000.TAR.GZ
Item2 = GRACENOTES - 4U5T-14G423-AC_1615425645000.TAR.GZ
Open2 = SyncMyRide\4U5T-14G423-AC_1615425645000.TAR.GZ
Item3 = ENH_DAB - 1U5T-14G658-AH_1644006443000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G658-AH_1644006443000.TAR.GZ
Item4 = APPS - NU5T-14G381-AB_1665525837000.TAR.GZ
Open4 = SyncMyRide\NU5T-14G381-AB_1665525837000.TAR.GZ
FILES (4)
NU5T-14G381-AB_1665525837000.TAR.GZ (869,8MB)
[06/12/2022 19:36:22] Selected Region: EU - Release: Sync 3.4.22251 - Map Version: Mantener Mapas Existentes
[06/12/2022 19:36:22] Install Mode: Auto-Detect (autoinstall) Forced: False
[06/12/2022 19:36:22] MY20 Protection: Auto-Detect
[06/12/2022 19:36:22] Formatting USB drive
[06/12/2022 19:36:22] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[06/12/2022 19:36:34] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06/12/2022 19:36:44] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[06/12/2022 19:36:44] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06/12/2022 19:36:49] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[06/12/2022 19:36:49] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06/12/2022 19:36:50] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[06/12/2022 19:36:50] Checking Existing File: NU5T-14G381-AB_1665525837000.TAR.GZ
[06/12/2022 19:36:50] Downloading: NU5T-14G381-AB_1665525837000.TAR.GZ
[06/12/2022 19:37:45] Validating: NU5T-14G381-AB_1665525837000.TAR.GZ
[06/12/2022 19:37:51] Downloaded: NU5T-14G381-AB_1665525837000.TAR.GZ
[06/12/2022 19:37:51] Preparing USB drive
[06/12/2022 19:37:51] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06/12/2022 19:37:51] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06/12/2022 19:39:41] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06/12/2022 19:40:13] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[06/12/2022 19:40:13] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06/12/2022 19:40:13] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06/12/2022 19:40:59] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06/12/2022 19:41:12] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[06/12/2022 19:41:12] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06/12/2022 19:41:12] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06/12/2022 19:41:17] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06/12/2022 19:41:18] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[06/12/2022 19:41:18] Checking Existing File: NU5T-14G381-AB_1665525837000.TAR.GZ
[06/12/2022 19:41:18] Copying: NU5T-14G381-AB_1665525837000.TAR.GZ
[06/12/2022 19:42:18] Validating: NU5T-14G381-AB_1665525837000.TAR.GZ
[06/12/2022 19:42:32] Copied: NU5T-14G381-AB_1665525837000.TAR.GZ
[06/12/2022 19:42:32] Generating Autoinstall.lst
[06/12/2022 19:42:32] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
