Update on 2020 models
Yes you can give the auto install a try. It may work and it may not.
The ideal way to install new maps is via a reformat but you must not do that on a 2020+ model year vehicle.
The worst thing that can happen if you force an auto install is that it’ll just fail (as in nothing happens/changes). You will likely receive an error message saying the install failed if that is the case.
Once again, make sure you force the auto install and do not let it downgrade/reformat.
